Question about Sony CDP-C305 5-Disc CD Changer
Loading a CD
The door will not open to put a cd in it
  • 2,071 Answers
First you do is to unplug the cord of your CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the CD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Posted on Feb 01, 2009
I have a crosley machine that records from tapes to cds .I can't get the door open to put my cd in . It clicks but won't open. Help, Please
Loading mechanism fault. Check the loading belt. If it is broken, CD won't eject, or load well inside the mechanism. If loading motor is damaged, this kind of fault can occur. Anyway, you have to take out the mechanism out of it to get it repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 15, 2014 | Crosley Audio Players & Recorders
My seal hifi, model number w3 7rw when CD is put in player the unit doesn't play CD, the door keeps opening
The loading sequence is not completing the cycle when the tray door closes because of slipping belt, or the laser pickup assembly is faulty.
Apr 15, 2012 | Audio Players & Recorders
Cd drive won't open
There is a pin hole in front of the tray door, put a fine screwdriver or needle in the hole push it in until you hear a click and it should pop open, pull the draw all the way, open until it stops, look under the tray you should see a small black belt "loading belt" if it's okay the loading motor is bad, The CD ROM driver needs to be replaced.
Jan 03, 2011 | Acer Aspire 5535-5050 Notebook
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Numark CD mix 3 right cd door seldom opens
Defective load belt or defect in laser assembly
Sep 11, 2008 | Audio Players & Recorders
There is a CD jammed in the cd player. (6 cd changer) It is a 2004 Ford Escape
It happens to me all the time on my 2002. Try cycling the load and unload buttons for the stuck CD location. If that doesn't work try ejecting the CD. When the slot door opens, try putting another CD into the slot and push on the edge of the stuck CD.
Jul 27, 2008 | 2002 Ford Escape
TEAC CD P1120 wont play
hi there krell
you definetly have a fault in your cd players main board best solution take to electrical shop and ask them to test all the circuits it wont cost much to get them checked out and see how you go
hope this helps and if you have the time please rate me if you dont mind
thank you
fixya
Jan 10, 2008 | Teac CD-P1120 CD Player
Sony CDP-C305 5-Disc CD Changer Logo
215 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
