Question about Bulldog Remote Stater w/Keyless Entry and 2 remotes
Remote starter will not start engine
Taurus remote starter will not start engine when blow 20 degrees C. but starts right up with key.
  • frstlght Feb 01, 2009
    Thank you
  • 15,935 Answers
Internal relay is faulty - replace the brain.
Unfortinately - There is no user-fix
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 01, 2009
2 Suggested Answers
MrScary66613
  • 1990 Answers
SOURCE: taurus remote will not start engine when blow 20 degrees C
Mine did the Exact Same thing. I went to the Manual and set it to Start every 2 Hours for 10 Min. when Below Zero Degrees and it solved this Problem. Please Rate My Response! Thanks!
My 2004 Ford Taurus remote starter will not start the car. All other remote options are working. How ever if I have the key in the ignition and press remote start it will start. Please help.
The problem here is the remote start system is not giving out the correct transponder code to the security system, this locks out the starter. As to how you program the remote start I have no clue as to what you need to do.
Oct 27, 2016 | 2004 Ford Taurus
2006 Ford taurus won't start, starter, altlernator, battery replaced, ignition starter switch, neutral safely switch changed, still nothing
I looked at info for your security system, it is starter motor disable. I didn't see 06 ford Taurus in my database, so I looked at 05.
Battery has a full charge and battery connections all good?
We can usually do some tests to see if starter motor will crank the engine, but, if the security is the problem, it still won't start.
You can check for applicable trouble codes? Try a different key?
Feb 16, 2018 | 2006 Ford Taurus
ON my 95 ford taurus the E.E.C. 30amp fuse blows every time I put a new one in it and then turn the ignition on to start it.
This means you have a dead short, you will need to look around engine area for bad wiring or component, you will need to start disconnecting components under the hood in the engine like injectors o2 sensors alternator , my first test would be to disconnect the small wire to the starter and leave the big one one for now and see if the fuse dtill blows, i have found this to happen when the starter is shorting out inside, if you turn the key and the fuse doesnt blow then replace the starter, remember the small wire on the starter. good day.
Aug 17, 2011 | Ford Taurus Cars & Trucks
20 amp fuse keeps blowing engine won't start, fuse
I am a mechanic,i had that same problem where my engine 20amp fuse were blowing....i fixed it...problem were a broken wire in the harnace on the side of the cylinder head....i made over $200 on that job...yahhh
Aug 01, 2011 | 2001 Mitsubishi Galant
When i turn the key i get dash lights ect. when i try to start the engine i get a (clickclickclick)sound.why?how fixd?
Change the starter relay. follow the positive cable to the relay, right by the battery. you can get the part at any auto parts store. take maybe 10 minutes. just follow the wiring from the old to the new, and two bolts secure it to the fender weld. I have a Taurus. Fix is about $10 to $20 depending on where you get it. hope this helps
Jan 17, 2011 | 1998 Ford Taurus
Security on. car wont crank. can trun key wont
verify that you have a fully charge battery and that you have the same amount of voltage at the battery as at the starter when the key is turned to the start position. If not repair fault at positive cable either at battery or at starter. If voltage checks good. Use a remote starter and turn key to the on position and try to crank over engine with remote starter. if engine cranks over. You have a defective starter solenoid and starter must be replaced.
Mar 26, 2010 | 1997 Infiniti.5 Q45
SECURILOCK ACTIVATED 99 TAURUS
your starter wire is red with light blue, If it was me I would double check all your wires or have a freind, sometimes you overlook things, ther is no rest for the securlock other than dissconect the neg terminal on the battery for 30 sec with the door open
Jan 14, 2010 | Directed Electronics 1100f Ford Pats...
1997 gmc truck remote start system not letting truck start with in ,i un plug and it fires right back up,if i plug remote start in it wont start with key but will with remote ,i unplug remote key will...
IF ENGINE CRANKS BUT NOT START -, sounds like a short in the tach wire, plug remote starter in and cut the tach wire to the engine for the remote starter. if the truck starts then you remote starter module is faulty.
IF ENGINE WON'T KRANK -, then there is a starter kill hooked in with it. if you bypass this you should be fine. just follow yellow wire from ignition switch till you find where it is cut. rejoin these two yellow wires and you should be good to go
Mar 07, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Taurus remote will not start engine when blow 20 degrees C
Feb 01, 2009 | Bulldog Remote Stater w/Keyless Entry and...
2004 Ford Taurus Dash and taillight fuse keeps blowing..
it sounds like who ever hooked up the remote starter may have crossed wires I would recommend takeing it back to who installed the remote starter and have them look to make sure something is not crossed in the system
Jan 02, 2009 | 2004 Ford Taurus
Bulldog Remote Stater w/Keyless Entry and 2 remotes Logo
144 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
baire
john h
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
