Question about Kitchen Ranges
Swithed to LP
I converted my maytag gas range over to LP, the stove come with the five jets for the surface burners. The oven was never mentioned and so I teid to use it. The flames from the burner filled the oven. Is there an adjustment for the oven? What do I need to do?
Chuck in Alaska My 1yr od maytag range lp fueled seems to be leaking, Ive checked the ports on the stove top all seem to be fine . I can't tell if it is the top or bottom oven. I did replace the ignitor recently and the smell seems stronger since but it was there before it was replaced. any place to look?
  • NUTTYPROFESS May 24, 2009
    i am trying to adjust the flame on oven and broiler.
    when turning the bottom nut,to reduce the flame to a blue,do you
    counterclockwise or clockwise the nut to adjust the flame?
    my e-mail is
  • Kitchen Ranges Master
  • 4,655 Answers
Natural Gas has a pressure at about 1/4oz psi. Propane runs at a much higher pressure 8 psi to 15 psi. For your safety do not use the oven until it is garenteed that the oven is rated for LP Gas!
Hope, this helps, Sea Breeze
Posted on Feb 01, 2009
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Is there something available to convert a hardwick propane stove / oven to run on Natural gas?
Should only be a matter of changing the jets, see a gas fitter if they can be changed.
Dec 20, 2015 | Maytag Crosley Hardwick Caloric Kenmore 8"...
Need instructions and part # for lp conversion kit on MGR5765QDS
Your conversion jets are usually located beneath the hinge area or the back panel on that stove and are mounted on a plate which holds all of the LP jets in a row. there is no need to buy a conversion kit, since it is already supplied. The jets mount on the burner control itself as it enters the gas flow tube, and the oven jet mounts just before the large burner under the plate in your oven area. Just remove that large oven floor plate and you will see it.
Mar 23, 2010 | Maytag MGR5765QDS Stainless Steel Gas...
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Conversion from electric to lp gas
Simple answer NO.
Unless Jenn-air has a conversion kit. (highly doubt this)
It would be a serious undertaking to switch out 2 burners for LP use.
Gas tubes, igniters, electronics, regulator, gas jets.
Not to mention the modifications changes needed to the stove top to make all this work. That gas regulator has to go somewhere and piping from tank/regulator/burners.
Not saying it can't be done mind you.
But think about it long and hard before committing to this job.
Small gas leak can become a huge headache later.
Oct 04, 2009 | Thermador PGR366 Gas Kitchen Range
Burners ignite but wont light
Are you on Natural Gas or LP?
If on LP, you may need to change the jets on the burners on top. Most times, when oven and broiler work and top doesn't, and you have spark, your jets are wrong size. Look on back of unit for a cardboard attached to unit, should have jets stuck to cardboard, if notgo to store where you bought unit and buy jets.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Swithed to LP
did you change the ovens burner orfice?if not theres your problem.
Dec 25, 2007 | Maytag MGR4451ADS Stainless Steel Gas...
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
340 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
