Question about Home
Bathtub caulk turning dark color in spots?
About 4 years ago I had the bathroom remodeled. A new surround wall enclosure and a tub put on top of the old one. It all still looks great except the caulking between the tub and the wall enclosure.
Its not coming off and still looks smooth and not breaking up. But,
in the past year its gotton dark spots in it. Not along the entire bead, but just in several places. We have tried to use several cleaners, but
nothing touches it. We use city water, and there is no sign of mold
anywhere else in the bathroom or the house. We had a new ventalation fan put in at the time.
So is there a way to touch up the color somehow, without recaulking?
Can it be "cleaned" out somehow with cleaner?
Is it just plan mold?
  • msny Feb 01, 2009
    Well I found this article.
    But I'm no expert at recaulking.
    http://www.doityourself.com/stry/mildewo...
  • Thomas F. Schneider May 11, 2010
    Yes. It is likely just plane mold. Try one of the mold removal products on the market made for this purpose. I beleive (TIle-X) brand might be one of them?
    Problem Solver:
  • 19 Answers
Ibelieve it is mold and the best thing to do unfortunately is re caulk it but use amold resistant caulking(kitchen and bath dap)
Posted on Feb 02, 2009
Want to fix bathroom issues and remodel it, how ?
sounds like you need to go visit a plumbing supply sales store . they have many great ideas and it will not be a BIRTH ROOM bath perhaps
Aug 17, 2016 | Mountain Plumbing Home
Knob and Tube Wiring...Which caulk is safe to use around it?
you can use silicone caulk for kitchens and bathrooms. this is the kind for caulking around bathtub enclosure and it comes in clar or white. can be bought at walmart , lowes or any good hardware or building supply company
Sep 14, 2012 | Cars & Trucks
Our tub has a lip around the top of 3 sides. The tub was either set in a little crooked or the wall is crooked. The inside corner on the faucet end of the tub the concrete wallboard is recessed about 1/8...
  1. 1
    Cut the tip off the tube of caulk, and load the fresh tube into the caulking gun. Puncture the seal inside the tip of the tube using a nail, stiff wire or the special puncturing tool built onto many caulk guns.
  2. 2
    Insert backer rod into large openings. These foam strips are available in sizes ranging from 3/8 inch to over 1 inch, and should be perfect for most bathroom filler needs. For larger holes, consider using a foam spray filler, but be careful as the foam expands a great deal and could overflow onto your work area if too much is used.
  3. 3
    Caulk the joints as you normally would. For large cracks, don't force your caulking into the crevice, but simply form a bead over the crack. Use multiple beads and a caulking tool or piece of scrap lumber to shape the caulk and remove excess.
  4. 4
    Allow the caulk to dry for 4 to 6 hours. Using the tip of your utility knife, check that the caulk adhered to all edges and formed a seal. For really large cracks, it may be necessary to repeat the process.
  5. 5
    When caulking open cracks, place a bead along each edge of the crack. Allow the caulk to set for 5 minutes, and apply a third bead over the first two. Use the damp sponge to shape and remove excess caulk.
Feb 04, 2011 | Home
We need to find a bathtub/surround that is 58" long, depth and width do not matter.
If you need it 58" the length of a tub is 60" so any enclosure will work. Most enclosure's will fit a tub that is 57" to 61" in length and come at 52" tall.
Good Luck hope this helps.
Sep 07, 2010 | NRS Zuma Tub Only w/ Surround - R7444TS -...
Need installation instructions for ASB model# 36850 Hudson tub surround
This is a 5 piece surround. For this project you will need the surround, polystryene adhesive, a utility knife, caulking and caulking gun, dish soap and the box the surround came in. On this type of surround the back and end walls are installed 1st and then the corner shelves are installed. Ensure the wallboard or substrate is clean and free of contaminates. Best to install new backer board or moisture resistant drywall first before proceeding. You will need adhesive specifically designed to glue the panels and corner shelving to the walls. Common product is PL700 from Lepage. Follow the manufactures instructions for the adhesive you are using. Avoid any adhesives not approved for use with plastics as they will damage the surround. Remove the tub spout, hot and cold water handles and diverter handle if your shower is equiped with one. Common diverters are a pull up on the tub spout. Install the panels with the bottom edge directly on the tub deck. For the end panel where the plumbing comes through you will need to cut access holes. Use the box that the surround came in as a template so that you are not accidentilly cutting holes in the wrong location. After installing the panels and shelving corners you will need to seal the seams with 100% silicone caulk. Peel the shelf edges back slightly and run a bead of caulk underneath the seam. Smooth the caulk line out. TIP Use a latex glove and dip your finger in dishsoap. The silicone will not stick to the dishsoap and will leave a clean fine line. Run a 1/4 bead of silicone where the surround meets the tub and also where the plumbing goes through the surround. Allow to dry and cure as per the manufacture's suggestions. TIP Install expanding foam in the cavaties of the shelving. This will provide a more rigid shelf and will extend the life of your new tub surround. Good luck with your project.
Jun 16, 2010 | Home
12 year old fiberglass tub originally white, now
home depot sell a bath tub remodelation kit.
it cost about $40 .
May 12, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
My tub surrounding is about a half a inch wide
You may want to try to find some thin ceramic tile beading and gluing it in place and caulking the remaining gap. Use a waterproof construction glue. This is most likely to be something you customize to fit. Often you can rent a ceramic wet saw and cut tiling to fit the need. Use proper safety gear, and be particularly careful if ripping thin pieces less you gain the nickname stubby.
Oct 07, 2009 | Whirlpool Safety Bath Walk In Bathtub -...
Old pink and purple bathroom needs help.
The consensus here is a medium to pale/light blue - black or dark blue would blend better, but it would be one darn dark bathroom. You want something that blends, not accentuates the purple.
Hope this helps :)
Mar 10, 2009 | Samsung HCN653W 65" Rear Projection...
How do I install a whirlpool bathtub?
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Feb 22, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Home Logo
745 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
