Question about Dell Inspiron 2200 Notebook
Dell Inspiron 2200 won't start
My daughter's computer stopped turning on, the battery doesn't seem to be charging.  Would this keep it from coming on at all, even when plugged up?  There are four lights beside the on switch that should  light up, only the far left one comes on steady and the second from the right flashes 9 times and then they go out.(they are green)  I figure I need a new battery, but don't want to buy one if it's something else. Thanks, Sheila
  • 15 Answers
First thing I would try is to unplug the machine, remove the battery and clean the contacts on the battery and in the battery housing with a pencil eraser. Blow out the shavings and reinstall battery - the way it sounds is that there may be dirt or corrosion causing an interference between the computer and battery contacts - for charging and powering up.
Posted on Feb 01, 2009
How to remove the battery of inspiron 2200
1. Turn your Dell 2200 laptop over.
2. Find the laptop battery release button lock for your Dell 2200 laptop.
3. Now that your Dell 2200 laptop battery is unlocked, find the battery release button down.
4. Holding the laptop battery release button, gently pull your battery away from the laptop.
5. Now that your Dell 2200 battery is removed, grab your replacement Dell 2200 battery for installation.
6. Insert the battery into the slot. Push the Dell 2200 battery towards the laptop and secure it in place.
Jul 04, 2016 | Dell Computers & Internet
Dell Inspiron 5160 doesn't charge
you mite have fried the power supply. or the battery.. try removing the battery and pluging it in,and then power it up
Jun 13, 2012 | Dell Inspiron 5160 Notebook
My dell inspiron 2200 does not recognize the battery, therefore, it does not charge it and the battery light continues to blink orange. Can you help me please?
The red light is indicating that there is a battery in the system that does not respond to charging.
if the computer doest regognize a battery at all i would nor react with orange blinking.
Start the computer without the battery in place,
only have the power cord connected,
There will be no blinking.
Dell use the "blink" to tell the user its time to buy a new battery.
If this helped, Please vote!
May 14, 2010 | Dell Inspiron 2200 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
When i am starting up my dell inspiron 2200 i just bought from a friend i get this message battery not identified and the thing is it says it is charged but i unplug it and it cuts off just like that i...
Sounds more like a hardware issue, see if you can check the battery with a multi-meter and see just how charged it is, if it's fully charged then it's most likely the battery sensor needing to be replaced.
Apr 03, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron Laptop powers off by itself.
This could be a couple of issues. One, the computer could be over heating and shutting down. Ask her if her laptop was warm and if the fan was constantly running. The second possiblity is the cord that plugs into the laptop has become loose and once wiggled will cause it to turn off because the battery doesn't hold a charge. Have her put the laptop on the table and with the computer running wiggle the cable. If it shuts down its a bad connector. In this case find someone with mad soldering skills and re-solder the connector on the motherboard.
Armymason
If this sounds like a good solution a high score is appreciated.
Apr 01, 2009 | Dell Inspiron 2200 Notebook
Labtop not charging
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
Clock
TRY CHANGING YOUR COMPUTER CMOS BATTERY, IT IS THE THIN FLAT BATTERY IN YOUR PC.
Feb 14, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
253 people viewed this question
Alun Cox
