Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Door on ice dispenser doesn't shut all the way.
My only problem is I don't know how to take the front panel part off so I can get to the problem and fix it. It's probably some as simple as a wire spring. One the left door where the water & ice dispenser are apparently visually there is no way to take anything apart. No screw that I could see or anything. Please help me.
    President:
  • 1,214 Answers
It's actually not a spring, but what they call a solenoid.
On some units -
Look at the underneath side of the dispenser trim, usually there are slots to put a screwdriver into to GENTLY!!!! pry it out at the bottom ( may be stuck on with double sided tape). After the bottom is pried out ,you SHOULD be able to gently lift it up and off small tabs that hook into the top part of what they call the escutcheon. Then everything is right there for you to tear into.
And on others -
Often the front trim will come off towards you if you carefully peel it back with your finger tips.
Let me know if you need more help. Will be glad to try and find you exploded views.
Posted on Feb 01, 2009
Water dispensing into ice maker won't shut off
There should be a float or electronic water level sensor that will tell the water to shut off, if it has calcium from the water on it or the float is damaged it will keep sending water until manually shut off(pull the plug). I would look for a water level sensor of some sort and clean or replace it. If that doesn't work it could be a sticking water fill solonoid which you should then replace
Sep 06, 2012 | General Electric GSH22JSXSS Stainless...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Our whirlpool ( ED22TW) no longer has water line attached, but we would fill up the ice bucket manually. The ice auger doesn't work when we push the lever on the front of the fridge. What's wr
On the freezer door at top where hinge is located a plastic hinge cover also covers a plug where many times the connection gets loose. Insure the plug is together firmly and all the wires are making contact. If that is not the problem then remove the ice bin push the freezer door light switch in as you press the dispense ice lever while looking at the motor coupling. Does it turn while pressing the light switch in as you also press the dispense button? If the first two test don't solve the problem then the micro-switch=> Micro-Switch-2162361-00564282
could be the problem. Let me know if I can answer any questions and I will try to get this going for you Thanks Sea Breeze
ED22TWXDN00 Parts Manual PDF
ED22TWXDN00 User Manual PDF
Jul 31, 2012 | Refrigerators
I described the problem poorly, I apologize. The freezer and fridge are at the proper temperature (freezer is at 0, fridge at 40). I've checked and the water flow from the wall into the machine is good...
Hello David ,
Their are a few possible reason the ice is not being dispensed,
1) the door switch is bad...the door must be closed for the ice to dispense and perhaps the switch thinks the door is open
2) the switch that is activated when pushing the lever on the dispenser is bad
3) the dispenser motor is bad
4) the control board is bad
GENE
Sep 23, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
WATER DRIPPING IN DISPENSER TRAY DUE TO ICE MELTING AT FRONT OF DISPENSER
Hi Don,
Typically this occurs when the dispenser door does not close all the way.
The dispenser door is located in the freezer door in the chute that the ice dispenses down.
With the freezer door open shine a light up from the outside and look down into the door from the inside. If you see light around the door flapper, you will need to replace the dispenser door, if there is a large gap between the dispenser door and the chute you will need to replace the mechanism that controls the door.
Apr 18, 2010 | Electrolux Refrigerators
How to get ice dispenser panel off front of door?
if its a whirlpoo at the bottom of the trim there are two slots use a flat head pull down and pry out
Jan 21, 2010 | Whirlpool Freezers
Ge model gsl251frfbs side by side. Ice maker/water dispenser not working when activated. makes ice, just won't dispense ice or water through front door. don't hear motor activating.
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Dec 16, 2009 | GE Refrigerators
Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Ice maker and water dispenser front panel lost power
Check the power connection for the door.. It is either under the hinge cover on the top or under the kick plate in the bottom.. Just un plug and re plug if it seems like the wires are fine
Good luck
Feb 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
