Question about Sharp R-1610 Microwave Oven
Work & Night light on Sharp R-1611 won't work.
There is power to the two light sockets but after I install the new bulbs they won't come on and there is not power to the sockets until I take the bulbs out. What is wrong?
  • Sharp Master
  • 9,156 Answers
Sorry I missed this one before, but if you (or anyone) has this trouble, the problem is no the control panel.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 20, 2008
  • 38 Answers
First check if light bulbs is ok these bulb are connected in series if one is fused both wont work 'first if u look at the two fiitings you would find a common wire disconnect from both .now you are left with two wires one connected to each fitting .disconnect from one fiting and conect to the other .now u will have one fitting connected and one totally disconnected .try bulb ifit works disconnect that fitting and try the other one .by elumination you will find out if the fitting is faulty
Posted on Jul 31, 2007
SOURCE:
Sharp r 270
FOLLOw this steps and see the picture attached. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Sep 30, 2013 | Microwave Ovens
Sharp R1480 OTR microwave night and work light won't turn on
Check you are getting 115 V with the bulb in circuit (safest way to test this is to solder a couple of bits of wire to one of the bulbs so you can access the terminals with the bulb inline (be careful), and then measure voltage across it.) The load imposed by the bulb may be causing the power supply to go into a protection mode - usually only if bulb is shorting, but may be a problem with the power relay. If there is a problem with the power supply, through the control board relay or otherwise, this will tell you for sure. Otherwise, if there is definitely the right voltage to a good bulb, then it will light. Check that the bulb is definitely making contact well, and make absolutely sure you have the correct bulbs for 115v, not the 220/240v ones. If this gives you no luck then please ask again with details of what you found. Hope this helps :)
Aug 16, 2007 | Sharp R-1460 Microwave Oven
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
Lights on bottom don't work. Sockets fell apart and vent fan now does not work. A bulb blew out , then all of this happened.
We see and repair this a lot. The problem is on the control board, which we regularly repair for $39.95 nationwide.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
We'd also recommend buying top-quality bulbs.
They can blow if subjected to vibration such as door slamming or a weak floor, or electrical fluctuation, especially if they are cheap bulbs or they are left on all night.
Instead of having the board repaired, you can order a new control circuit board / smart board if that's economical, and since your sockets are bad, they will need to be replaced, too.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your
favorites.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you're changing the board yourself, you'll need to detach the keypad connector:
Some connectors will have a lock.
Dec 27, 2012 | Microwave Ovens
Sharp carousel R1472A Over the range microwave. Night light on microwave that shines down on range top will not work, Help! Yes, has two new bulbs.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Yours is similar to this one:
Apr 25, 2011 | Sharp Microwave Ovens
Sharp Carousel Microwave work light/night light has two light bulbs. One light will turn off by pressing the panel control, but the other light remains on. Must remove light from socket in order for the...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 29, 2010 | Sharp R-1610 Microwave Oven
I have a Sharp model R-1610 Microwave. The work/night light does not work. I"ve changed the bulbs.
Does it operate with a membrane-type touchpad?
These things seem to be problematic as the microwave ages.
They are usually replaceable, and the cost is not great. I just installed a new touchpad on an LG, and it cost $25.00 plus shipping.
Oct 12, 2009 | Sharp R-1610 Microwave Oven
Same for us. The night light and work light do not work.
Simple screw driver to remove the cover plates on the bottom of the oven and the bulb unscrews. Install a new appliance bulb and your back in business.
Jul 04, 2009 | Sharp R-1481B Microwave Oven
Work light and night light do not work on Sharp Carosel R-1481
> Work light and night light do not work on Sharp...
Thanks for giving us the model number.
We regularly repair these R1481 control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Nov 22, 2008 | Sharp R-510HW Microwave Oven
Lighting Problem
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Mar 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1610 Microwave Oven Logo
158 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
