Question about Dynasty DBQ-30 (LP) Grill
Need 3 burners for Dynasty gas grill model DBQ-42-F-L .
Looking for dealers/parts suppliers in Santa Barbara, Ca. area.
  • Anonymous Mar 30, 2009
    I need 2, just ordered from sears online. A few days later, found out no longer instock.
There is one on Ebay: do a search, NEW For Jade Dynasty Grill BBQ DynaChrome Burner. the item number is: 130362941787
Posted on Feb 02, 2010
  • 11,896 Answers
Www.appliancefactoryparts.com
www.Grill-Parts.com
www.appliancefactoryparts.com/gasgrillparts/brands/dynasty/dynasty-other-parts.html
Posted on Feb 01, 2009
Grill burner will not burn like the other
Dynasty burners are replaceable and they are very good appliances (when they're actual dynasty, manufactured by jade).
About 90% of the time someone complains about burner flames or heat it is the check valve needing to be reset. I explained this earlier but let me know if you need to know how to do this.
On the rare occasion the check valve is not the problem (and 90% could actually be very low because this is almost always the problem!) the burner could need to be cleaned or replaced or the gas orifice and valve could need to be cleaned or replaced.
Dynasty burners are very heavy cast iron, single venturi "H" burners. Although coated cast iron is quick to oxidize and sometimes because of the coating the rust will start from the inside out. Lift the burner from the back of the barbecue and slide it away from you. Check to see if it is corroding from within.
The single venturi tube extends from the bottom of the burner into the control panel where it slides over the gas orifice at the tip of the control valve. It is possible for the gas valve to get a small insect crawl in through the orifice and build a nest inside the small cavity inside the control valve.
Remove the burner to reach through the inner firewall with a ratchet to pull the orifice and then check the inside of the orifice and the inside of the valve behind the orifice. If something is clogging the orifice the gas will flow unevenly and you may have flame-flashing inside the control panel which will destroy the lubrication in the control valves and will destroy the ignition parts inside the control panel.
I suggest the check valve solution with the drip tray removed so you can look from under the control panel for gas leaking through the air holes in the venturi tubes. Also, remove the control panel and leak-test the valve with soapy water because if previous flashing occurred the first casualty is usually the seal between the valve and the gasket which can lead to more leaking gas.
Check valve:
Turn everything off (tank and bbq).
Disconnect hose and regulator from LP tank.
With tank disconnected, turn the BBQ on. Turn every valve to "high" and leave it for 5 minutes.
Turn everything off -- completely off.
Reconnect tank but turn the tank on very, very slow. The check valve problem occurs when gas "hits" a swing arm too hard as the gas leaves the cylinder so turn the cylinder on very slow and then relight the grill.
Jan 25, 2014 | Dynasty DBQ-30 (LP) Grill
Do Jenn-Air have recommended suppliers? I have a Jenn-Air Gas Grill Model 720-0163 and need burners.
Appliance Factory Parts http://www.appliancefactoryparts.com/ is a good place to start. They carry parts for just about all makes and model grills. If you can't find what you need under Jenn Air, try looking under NEX Grill. Actually, they are the manufacturer of the Jenn Air Gas Grill.
Hope this helps you. Please let me know. Happy Grilling.
Jun 26, 2011 | Grilling
We used to have a natural gas line to the Capt n cook grill (3 burner). What part do I need to make it for propane?
You need to change the orifices ... available from your propane supplier along with a little primer on how to install, Im sure.
Thanks for your interest in FixYa.com
Jan 27, 2010 | Barbeques Galore Capt'n Cook 3-Burner...
I need 3 burners for Grand Gourmet Gas Grill Model No. GBC621A-M
Try this link: http://www.grillstuff.com/grill-parts/brinkmann/810-2300-b/?cat=27&brand=5&model=8938
It should bring you right to your specific grill and list replacement parts including burners.
Cheers!
Sep 08, 2009 | Brinkmann 810-2300-B Grill
Bynasty BBQ - Need briquette trays; left, right(
They have them at DynastyStoves.com/parts.php
30 inch models need one notched and one regular tray. 42 inch grills need two regular and one notched. they have the briquettes too.
Jun 30, 2009 | Dynasty DBQ-30 (LP) Grill
Who carries Dynasty parts?
Jade Products in Brea Ca 714-961-2437
Jul 06, 2008 | Dynasty DBQ-30 (LP) Grill
Dynasty DBQ-30 (LP) Grill Logo
684 people viewed this question
Top Dynasty Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Dynasty Grilling Expert? Answer questions, earn points and help others
