Question about Garmin Nuvi 660 GPS Receiver
Volume made a couple of odd noises and then stopped speaking
We were traveling and the garmin, Jack, just made a couple of odd noises and then he just stopped speaking. We tried resetting as well as re starting, changing voice to Jill but no sound. The screen works fine but no verbal directions. Help We also checked the volume level and they are at 100%
  • 20 Answers
Plug a headset into the audio jack and see if there's audio when Jack or Jill speak. If no audio there, you've got a defective audio amplifier stage. If audio can be heard through a headset, you've got a blown speaker.
You'll need to send it back to Garmin for repair in either case, though in the case of a blown speaker, you <could> use external Ipod-type speakers, if you didn't mind the kludge.
Posted on Feb 07, 2009
Nuvi2550 has no audible voice prompts
have you cked if it is muted? touch the speaker and when the volume control comes up you can see if it is muted
Dec 05, 2011 | Garmin GPS
I have the Plantronics S11 headset and I can hear callers, but they can't hear me, I need to know what to do. The phone is working fine and everything is all set up correctly as far as I can tell.
There are a couple of basic things to check first. You want to make sure the mute is turned off and your outgoing (mic) volume is loud enough (there is the speak level switch on the side and the speak volume control on top). Also, you want to make sure it is connected through the handset jack on the phone (generally it will not work through the headset jack on the phone). Finally you want to make sure it's configured right (scale located on the side).
Good Luck from Headsets Direct!
Jul 04, 2011 | Plantronics S11 Headset
Have a uniden pc 68 elite it seems everything works the whene transmitting the needle moves a. but it has no volume it makes no noise i have tried a different mic i have put a new ext speaker on it and it...
Could be audio chip.
  • Insert external speak jack into pa port.
  • Turn volume down
  • Switch cb/pa switch to pa
  • speak into mic
if you are getting audio from speaker ......chip is fine.
Jan 04, 2011 | Uniden Bearcat Pro PC68Elite 40-Channels...
My garmin 205w doesn't tell me verbally names of streets and exits. My brother has the same exact model and his does this function.
Some of the voices on Garmin satnavs speak streetnames and others don't. Press Tools, then press settings, then press Language. You'll see the Voice name. Press it and select a different one. (American English Jack or Samantha TTS will speak the streetnames). Press OK and it should then be ok.
Aug 14, 2010 | Garmin nuvi 205 GPS Receiver
My Nuvi stopped speaking, the volume is 100% and the mute is not selected. What next?
Contact Garmin Customer Support
North America - Consumer Products
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Feb 08, 2010 | Garmin nuvi 205 GPS Receiver
The speaking part just stopped speaking. Is there something Iam doing wrong? The volum is up 100% but nothing happens as far as the speaking voinc on the Garmin.
check that you have not activated MUTE and also go to settings and select another voice be sure to select a TTS (text to speech)
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Garmin nuvi 350 GPS Receiver
I can not get my garmin 2620 to talk to me
In order for the GARMIN 2620 to speak to you it must have the speaker attached. The speaker is included on the car adapter plug. Without this special 12V car adapter you will not be able to get sound from the Garmin 2620. If you have the adapter with the built in speaker, make sure the volume isn't muted, and is turned up by pressing and holding the Speak key or adjusting the volume on your 2620 remote.
Nov 10, 2009 | Garmin StreetPilot 2620 GPS Receiver
Garmin 265 W won't speak street names
Below is the procedures for setting the languages...
Touch tools > settings > language > voice.
Voice- changes the language for voice promts.
Languages noted with a persons name are (tts)
text to speak voices.
which have an extensive vocabulary and pronounce
the street names as you approach turns.
The pre-recoreded voices (those without a persons name)
have a limited vocabulary and (do not speak names of locations or streets)
Text language- change all on-screen text to the selected language,
changing the text language does not change the language of user entered data
or map data, such as street names.
Keyboard- select the keyboard for your language,
you can also change the keyboard language mode from any keyboard
by touching the mode button
Adjusting the volume levels
From the "menu" page touch "volume"
to adjust the volume.
To adjust the volume levels for the media player
and the navigation prompts,
please click.
Tools > settings > Volume > Restore
Restore will, restore to origional volume levels.
Regards
Richard
Apr 26, 2009 | Garmin nuvi 205W GPS Receiver
My Garmin 760 does not speak street name on the turns. How to set dthis?
On your GPS device, Touch settings>Select language>Select Voice and select the TTS(Test To Speech) man or women to speak.
Make sure the volume is up, and the mute is off.
The pre-recorded voices(those with out a persons name) have a limited vocabulary and do not speak names of locations or streets.
hope it helps you out
JADF
Apr 13, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
155 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
