Question about Bulldog Remote Stater w/Keyless Entry and 2 remotes
Taurus remote will not start engine when blow 20 degrees C
Will not start engine when blow 20 degrees C. but starts rght up with key.
  • frstlght Feb 01, 2009
    Thank you, but my manual does not give instuctions on programing. I have a Ford installed remote starter featuring PowerCode Technology.
    President:
  • 1,990 Answers
Mine did the Exact Same thing. I went to the Manual and set it to Start every 2 Hours for 10 Min. when Below Zero Degrees and it solved this Problem. Please Rate My Response! Thanks!
Posted on Feb 01, 2009
  • Travis Humphries
    Travis Humphries Feb 01, 2009
    My Bad! I gave you Info. for the Bulldog System.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
20 amp fuse keeps blowing engine won't start, fuse
I am a mechanic,i had that same problem where my engine 20amp fuse were blowing....i fixed it...problem were a broken wire in the harnace on the side of the cylinder head....i made over $200 on that job...yahhh
Aug 01, 2011 | 2001 Mitsubishi Galant
THE AC IS NOT WORKING WHEN THE TEMP IS SET TO 60 DEGREES EVEN ON VENT IT BLOWS HOT
chances are you need to have your compressor charged with freon. turn the AC on and then raise the hood and listen for a clicking sound while the engine is running. If it clicks several times during a 20-30second span then you are low or out of freon.
May 06, 2010 | 1999 Ford Taurus
Wont turn over under 20 degrees
your ignition switch is bad in the start position,or there is a broken wire in the harness..
Apr 14, 2010 | 2003 Volkswagen Jetta TDI
SECURILOCK ACTIVATED 99 TAURUS
your starter wire is red with light blue, If it was me I would double check all your wires or have a freind, sometimes you overlook things, ther is no rest for the securlock other than dissconect the neg terminal on the battery for 30 sec with the door open
Jan 14, 2010 | Directed Electronics 1100f Ford Pats...
1996 Ford Taurus will not start. The car has power and gas.
spark coils are located on top center of the engine under hood. wiggle connections and see if there are any loose. If you can not find the coils, follow the spark plug wires back from the spark plug it will lead to the coil. good luck
Nov 16, 2009 | 1996 Ford Taurus
Remote starter will not start engine
Internal relay is faulty - replace the brain.
Unfortinately - There is no user-fix
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 01, 2009 | Bulldog Remote Stater w/Keyless Entry and...
2004 Ford Taurus Dash and taillight fuse keeps blowing..
it sounds like who ever hooked up the remote starter may have crossed wires I would recommend takeing it back to who installed the remote starter and have them look to make sure something is not crossed in the system
Jan 02, 2009 | 2004 Ford Taurus
Factory remote starter
I would suggest you obtain the install instructions from the dealer and check that it was wired into the system correctly. Another thought is that the remote needs to be programmed, that was a common issue when I worked for a Ford dealer.
Jun 30, 2008 | 2002 Ford Taurus
Bulldog Remote Stater w/Keyless Entry and 2 remotes Logo
96 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
