Question about RCA DRC8300N DVD Recorder/VCR
Pictue but no audio on VHS playback..VHS record to DVD visual/no
Playback of Vhs to tv gives picture but no audio.
Transfering VHS to DVD gives visual but no audio.
Recording camcorder to dvd gives visual but no audio
Playback of apreviously recorded dvd is good for both adio and visual.
model DRC8320n purchased Dec.2008 new.
    Problem Solver:
  • 5 Answers
Sounds like your audio connections between the DVD/VCR and TV are unplugged, loose, or damaged. Try substituting an audio cable that you know is working correctly. Also, make sure you have everything plugged in to the right ports (output on DVD, input on TV).
If none of that works, you might have a damaged port on your DVD or TV. To check the ports: remove the cable plugged into it, then lightly wiggle it in all directions (do NOT force it to move if it has ANY resistance). If the port moves at all it probably has broken solder points inside the device.
If there is a bad one on the TV you might be able to just plug everything into a different set of input ports, if you have some. If it's on the DVD, you're stuck with either replacing it or getting it repaired (unless you know how to solder, but I doubt that you would).
Posted on Dec 16, 2011
  • 790 Answers
Hi
please check the format settings, maybe the audio is not in good settiongs!~
Thanks!
Posted on Feb 01, 2009
Head alignment
Tracking controls for VHS should have no effect on the DVD player. If a pre-recorded DVD is distorting the picture, along with the VHS, then there's either something wrong with the TV it's played on, or the connection, between the two. Or there is a fault in the electronics of the VHS/DVD combi that deals with the picture.
Dec 29, 2013 | Zenith Televison & Video
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
Which DVDs do I need to use with the Toshiba DVR19DTKB2 I have DVD+R Will these record from VHS
Compatibility Recording - DVD-R, DVD-RW, DVD+R, DVD=RW, VHS
Compatibility Playback - CD-Audio, CD-DA, CD-R, CD-RW, SVCD, Video CD, DivX version 6, DVD-R, DVD-RAM, DVD-RW, DVD Video, DVD+R, DVD+RW, JPEG Viewer, MP3, NTSC Playback (VHS), USB 2.0
Mar 07, 2011 | Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
LG RC195 dvd/vhs combo
Do you just get a snowy screen when you playback? I think the first thing to try is to clean the video heads. Either try a head cleaning tape, but these are not always the best thing, better still is to remove the lid & carefully using a head cleaning fluid (isopropal alcohol) & a thin piece of card or head cleaning stick (NOT a cloth), carefully & gently wipe the heads which are on the round silver drum. Do not use too much pressure or you will damage the heads, give it time to dry (couple of minutes) & then try playback.
Jul 20, 2009 | LG Televison & Video
How to finish a transfer from VHS to DVD?
When you finish recording from VHS then press Stop on dvd recorder and finalize dvd, this option would be available in dvd menu.
After finalization, that burned dvd can be playback on any dvd player.
Apr 19, 2009 | Televison & Video
I have a vhs/hq ..i have visual but no audio for a program i recorded last thursday. I tried recording from tv now and still no sound but picture. I played other movies or previous recorded things in vhs...
Try first to ensure that the scart lead at the back of the set or any AV leads that you are using are secure and tight.
Sometimes if the scart lead is not pushed home correctly it will lose audio. Try then to record a sample of video and try playback.
If there is still no sound try another scart lead first.
It will be a process of elimination I'm afraid.
Regards
Marc
Apr 17, 2009 | RCA DRC8300N DVD Recorder/VCR
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
Vhs playback problem
either extremely dirty heads or there is a tv/vcr button that needs to be toggled. Most have auto tracking, old ones have a knob or 2 buttons under a panel somewhere for tracking.
Dec 02, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
RCA DRC8300N DVD Recorder/VCR Logo
186 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
