Question about Rubinet 41RBHOBK H2O 1/2 Temperature Control Shower 41RBHO in Black
Triton Silhouette LED temperature fluctuations
Hi, I was wondering if I can repair my Triton Silhouette electric shower. When you turn it on and throughout trying to shower it fluctuates between 30-52 degrees Centigrade. ie. very cold and very hot. this climbs and decreses on the temperature LED display. Can I fix this myself or do I need someone to come in or is it simply better and cheaper to replace? Any guidance would be fantastic. Regards Katrina
  • Anonymous Mar 31, 2014
    The flow when turning on the shower is not good i.e. fast then slows down. At the same time the temperature of the water fluctuates. I am an elderly disdabled person and am afraid to shower now as I@ have had a lucky escape twice.
  • 34 Answers
Yes this one for the pro's call the company this is not something a most repair plumbers like to do...we would call the company they should know whats going on. If I was on the job thats what I would have to do, and then I would have them ship the parts to me. How old is it?
Posted on Feb 06, 2009
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Unpredictable water temperatures!
i am not an expert but i have a hunch it could be the tempeture gauge but i have no solution sory
Jun 19, 2012 | Home
Triton t80si shower is very hot even on a low setting then fluctuates between hot & cold, pressure switch is not activating but pressure seems low any advise will be gratefully received.
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Jul 09, 2010 | Home
Fluctuating water temp. It is hot when I start the shower,
Iam guessing your using it faster than it makes hot water. May need a larger unit or a second one,in the system
Apr 10, 2010 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
Triton jade 2 shower not generating sufficient heat
your element needs de caling i suspect
Nov 11, 2009 | Home
TRITON TOPAZ SHOWER T 100i no hot water
I would check utube first for possible repair. not knowing whether yours is gas or electric, I would have to recommend contacting the manufacturer.
Dec 09, 2017 | Kitchen Appliances - Others
Shower either runs cold or extremely hot
hi ya, if its a triton shower valve & only 2 years old it should have a 5 year guarantee, ring Triton & arrange a service call.
it sounds as though the filters could be blocked & more than likely the thermostat requires replacing as its more than likely scaled up?
You never mentioned where your based UK or abroad?
Kindly
Richie
Dec 15, 2008 | Home
Rubinet 41RBHOBK H2O 1/2 Temperature Control Shower 41RBHO in Black Logo
276 people viewed this question
Top Rubinet Home Experts
john h
Tom Chichester
Are you a Rubinet Home Expert? Answer questions, earn points and help others
