Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire ltf6000es that will not drain
It is about 2 yrs old and it was spinning clothes and gave my wife an error that see looked up and it stated to unclog drain cup in black hose but now it won't do anything. If you set it to wash it just decreases minutes until done but doesn't fill or anything. Is this something I can fix or is there some type of reset?
  • Anonymous Feb 04, 2009
    the front loader motor comes on, a little rattle, and the spin cycle won't go beyond slow, so it leaves the clothes soaked.
  • onthethejob1
    onthethejob1 May 11, 2010
    whats the code e23????
  • 11 Answers
Your washer has a clogged drain, it is usually a clogged filter assebly under the machine. If you are not handy, you may need to call a repair man. If you are handy and can handle getting into tight places, than it will probably take you about an hour to fix. The filter assembly gets clogged with coins, and lint from the wash, and than causes an error. I hope this is helpful to you.
Joe the Plumber
Mid-Hudson Heating & Plumbing
Woodstock, NY
Posted on Feb 05, 2009
Washer will not open, drain or spin.
if the error code is SE it needs 2 be manually drained
Apr 16, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My frontloader starts out fine , but when time to drain, it spins and only a small amount of water comes out,the spin cycle is so load and moves the washer while spinning also the cycle ends and the...
check water pump , from your discription i beleive you have a blockage before the pump this would account for the small amout of water removal
NEVER OPEN MACHINE CASE WITH REMOVING POWER PLUG FROM THE MAIN POWER SUPPLY
Jan 16, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer will not spin out, it is not flashing
intersting when mine did this it was the pump... maqy i ask how you checked your pump? and can they be cleaned i just had to replace mine and its only 2 yrs old, i dont want to have to replace every 2 yrs
Dec 30, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire GLTF2940FS...does not do a final spin/clothes wet
If water remains in the drum the unit will not go into the final spin.There may be a couple of reasons for your problem.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. I believe the pump is about $60.00 and is accessible after removing the front panel under the door.
Sep 10, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer not spinning
Unsrew the bottom panel and u will find the pump to the right disconnect the hose from the back thats coming down from the tub.You will find a pocket behind the hose connect filled with all kinds of change probably enough to buy a pizza and a couple of beers. I also had a old credit card,gas pass bobby pins,hard plastic tags.chains and a hand full of sand.
My Frigidaire frontloader is 9 yrs old was close to buying a new one but this defintly fixed the problem..
works like new again.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
137 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
