Question about KitchenAid KESC307 Electric Kitchen Range
Sa66 or sabb
Can't get to come on
  • melaniejsull Feb 03, 2009
    Yes it worked! By the way what is sabboth mode, we are renting and there is no manual any where is this house.
Your oven is in sabbath mode -
Open the oven door, press cancel/off then press and hold the number SIX for five seconds.
That should do it.
Posted on Feb 02, 2009
  • waimeamom Feb 03, 2009
    Glad it worked!!
    Sabbath mode is I think something to do with Jewish religious law - about not having anything working in the home over sabbath. I'm not entirely sure.
    I think there's a manual that someone has posted on this site for this type of oven. It should show up on one of these pages, or maybe if you search...
2005 sabb 9-3 sabb heater doesn't blow hot air. blowers work fine.
The valve regulating the water flow to the heat exchanger could be broken. It needs to be replace.
Jan 20, 2013 | 2005 Saab 9-5 Sedan
P0131 sabb 93 2001 po121 error codes
P0131 - O2 Sensor Circuit Low Voltage Bank 1 Sensor 1 (sensor is before the catalytic converter)
Possible causes- Front Heated Oxygen Sensor Bank 1 harness is open or shorted
- Front Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Faulty Front Heated Oxygen Sensor Bank 1
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks
P0132 - O2 Sensor Circuit High Voltage Bank 1 Sensor 1
- Exhaust gas leaks
I am not really sure what is going on here with the same O2 sensor giving these lean and rich codes, if nothing else is apparent and the engine runs well you may have a defective O2 sensor.
Sep 13, 2012 | Saab 9 3 Cars & Trucks
I just got a 2002 95 sabb with 95k on it the check enjine light came on, ran diagnostics on it and it didnt come up with anything for a sabb only a bmw somthing about troubleshooting p1181 is this a...
1) make sure there are no leaks / loose hoses in the air intake system 2) Clear the MAP sensor which is to the front of the passenger side of the car just under the hood. Big square thing inline with air intake. 3) Get a known good MAP sensor and see if code is still happening.
Aug 11, 2010 | 2002 Saab 9-5
Sabb fixed...now err with temp.
posssible that youve now switched from farrenheit, to celcius. manual will explain how to shift back
Feb 26, 2009 | KitchenAid KESC307 Electric Kitchen Range
ERROR CODES
The following are generic OBD II codes so your Sabb may not conform:
P0507=Idle Control System RPM High
P2187=Sys Too Lean at Idle Bank1
Oct 06, 2008 | 2004 Saab 9-3
Bezin spending
What is the question, is it about fuel mileage?
Sep 15, 2008 | 1995 Saab 900
Range shows 'SA 66" in display
After calling customer service with no satisfaction, I did a Google search for SA66 which turned out to be really SAbb code. I found out that this is a special "Jewish Mode" that I somehow turned on while pushing the touch pad disabling it. To end the "Sabbath Mode", Press CANCEL/OFF FOR ONE SECOND, then press and hold Number Pad 6 for five seconds. It worked!
(You can also press and hold the Number Pad 6 for five seconds first, followed by CANCEL/OFF.)
Mar 07, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
296 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
