Question about Panasonic KX-TGA560B Cordless Expansion Handset
PHONE IS ON CONFERENCE. cAN'T TURNOFF CONFERENCE AND AM NOT RECE
Phone is on conference and I can't turn it (conference) off. Can't receivie incoming calls.
  • 201 Answers
SOURCE: Toshiba Strata DK280 Conference Phone
Are you talking about a special speakerphone that is not made by Toshiba? This would be a single line phone device not a proprietary Toshiba phone and you would need a special card in your system that can handle single line devices. You may already have one that has a free port on it.
However, it does sound like you would need to find help from a local phone system installation company. You cannot plug a single line phone into any phone port on your system. A special wire would need to be run just for that phone and the system would need to be re-programmed for that port. If you need a single line card it will be even more complicated.
Posted on Nov 14, 2007
SOURCE: conference calling
While tlaking to 1st party press 'CONF' button,
Dial 3rd Party's No. (0' first for outside line)
Press 'CONF' Button
Posted on Feb 18, 2008
SOURCE: Conference call
The problem has been resolved.
Posted on Mar 25, 2008
Centernet
  • 38 Answers
Depending on which system you are using (not the telephone) and how it is programmed, you may not be able to go beyond a 3 party conference. Some systems allow up to 8 parties. Just press Conf, attach to another call, and then press Conf again to go into the Conference. As they say, "Repeat as necessary."
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
  • 32 Answers
SOURCE: 3- way conference call with tga542m?
One of the two "soft buttons" at the top of the keypad (first row of keys under the handset's display) should read Flash when you are on a call. Hit that button, you'll hear the line tone, dial the number and wait for the other person to answer. Hit Flash again and they should be joined together. If not, you may need to subscribe to Call Waiting/3-way Calling through your telephone company.
Posted on Jan 08, 2009
Can anyone tell me how to place a conference call using the Polycom SoundStation2 when both calls are incoming? I am able to place an incoming call on hold and dial another number and conference them...
No it can't. One call at least must be dialed out to. Try using a conference bridge service if you want to have multiple parties call in to you. Then you and all guests only need to call bridge number which is usually toll free.
Feb 21, 2011 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Panasonic kx t7436 how many conference will do conference
you can do as many conferences as you have phones, but one phone can have one conference at a time with 3 total parties(depending on your phone system) in the conference (so yourself and 2 other people, inside or outside of the office)
if you have a TDA/TDE/NCP phone system (blue box on the wall or in a computer rack) you can have 5 people in a single conference...
if you have a TD phone system (white box on the wall) you are limited to a 3 party conference
Jan 06, 2011 | Panasonic KX-T7436 Phone (KXT7436000000)
MITEL 5303 Conference Phone question: during connection of a few numbers and 1 number is busy - how do you drop that call without dropping all parties connected?
I believe that if you reach a busy signal, you can hang up. The conference should ring you back and the rest of the conference will be there.
Here's what the documentation shows from within the help of a 3300 ICP/MCD...
a 5303 is to be treated just like a 2500 series set...
2500, 5302 IP Phone, SUPERSET 401, SUPERSET 401+, and SUPERSET 4001 telephones:
To form a Conference when a two-party call is already in place, or to add another party to an existing Conference:
  1. Press Flash or flash the switchhook.
  2. Dial the number of the next party.
  3. Wait for an answer.
  4. Press Flash or Flash the switchhook.
  5. Dial the Conference Call Feature Access Code.
To Leave a Conference:
  • Hang up.
2500 telephone:
To split a Conference and speak privately with the original party:
  1. Flash the switchhook.
  2. Dial the Conference Call Split Feature Access code.
Sep 30, 2010 | Mitel 5303 Conference (50001905)
How do I start a conference call on a Mitel 5303 Conference Phone? It states it only hosts up to 8-10 people.
I'm assuming you are using this on a 3300 ICP. In that case, the phone system is only able to do 8 party conference calls without an external Conference server.
You can dial the first number, press the flash button, dial the next number, dial the feature code (get from your vendor), repeat until you have all parties as part of the call.
The 5310 IP conference unit works much easier than this phone. A conference bridge such as Audio Web Conference with the appropriate licensing will allow for extended conference calls... it will also allow you to record the call for later "off-air" participation.
Sep 23, 2010 | Mitel 5303 Conference (50001905)
Need the Avaya phone type to set up the ClearOne Max Ex Conference phone
Wha???? This is an analog conference phone. Plug it into an analog phone port....
Not sure what your question is.
Oct 16, 2009 | ClearOne Communications ClearOne Max EX...
Conference calls
Press the conference button, dial your third party, once connected, press conference again, that will bring all parties together.
Nov 18, 2008 | Lands Phones
CONFERENCE CALL OPTION
dial phone number and wait for connection. Once connected press conference key, dial second number, once connected press conference key again and all 3 parties are connected. ldtsnj.com
Sep 29, 2008 | NEC DTU 8D-2 Corded Phone
Conference call
Sep 26, 2008 | Panasonic KX-T7633 Corded Phone
Extension Mics on the Polycom Audio Conference Phone SS2W/EX are very faint
Please I have the same issue, the receiver cannot hear whjat we are saying our voice is very faint to the receiver as if we are calling from a very far distant location from the phone.
Aug 08, 2008 | Polycom SoundStation 2W (2200-07800-001)...
Conference calling
Press 'CONF' Button
Feb 12, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-TGA560B Cordless Expansion Handset Logo
43 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
