Question about Dewalt D55146 Factory Reconditioned 4.5 Gallon Electric Wheeled Portable Compressor, 1.8 Hp, 1750 Rpm
Compressor question i've had a dewalt compressor D55146 for a while now and just recently the compressor started to stay running at all times and not much pressure was building in the line..... the pop off valve is not open, ive tryed to adjust the pressure adjustment knob up and down and to no luck...... any help would greatly be appreciated shilo please respond to impalassondubs@aol.com
  • 95 Answers
I have that compressor and had that problem. i build professionally so i use it alot. i had it about a year before the regulator quit working which is what yours is doing. i put it back in the box and took it back to lowes
please rate answer
Posted on Mar 21, 2009
My dewalt D55146 makes loud leaf blower noise, has a burning smell and doesnt build pressure
This compressor is belt driven. When the belt fails the motor will run faster than normal and takes longer to stop turning. When belt is in place and the motor is shut off, the motor will stop almost instantly. If the belt is slipping, you will smell rubber burning (you will need to change the belt anyway). It is my opinion that the belt fails because the cut-off pressure is much to high (200psi). The belt will last longer is the pressure switch cut-out at a normal 125psi. If the discharge tube (tube from pump head to tank or in-tank check valve) or other parts are leaking, it will take much longer to fill and cause over-heating. You can keep track of the condition of the compressor internal parts by knowing how long it takes to fill the tank when new compared to how long it takes now. As parts wear, the unit will take longer to fill. Go to the dealer and time a new unit then test yours against this time period. Do not use an extension cord on this size compressor. Use more hose instead. If you are having trouble filling the tires because of low pressure in the hose, try experiment. Remove the safety valve from the compressor and install a tee fitting. One one port of the tee, reinstall the safety valve. On the second port install a quickconnect fitting. This will give you access to full tank pressure bypassing the regulator to quick fill your tractor tire. This trick is how the tire shop quickly fills a tire. Use caution and do not overfill your tire. Good luck
Apr 11, 2013 | Dewalt D55146 Heavy Duty 412Gallon 200PSI...
Dewalt d55146 wont start
Not that I am aware of. The cord should go into a control box where the on off switch is. The motor wires come from that to the motor. I would check the switch box and more importantly the cover. The cover contains the plastic knob that turns the switch on and off. If the knob gets messed up it may not work correctly. The cover is available by itself. Here is a diagram with the part numbers.
DeWalt D55146 diagram
Aug 20, 2012 | Dewalt Air Tools & Compressors
My regulator on my compressor keeps leaking from the top. When I turn on compressor it just keeps filling up in the regulator maxes out at 200psi and blows the safety valve. model D55146 type 2
Hello. W/D here.
Check the rating tag on the safety valve that is letting the pressure off of the tank. I'm pretty sure that it is less than the 200 psi that you are seeing.
What I believe is that the contacts in the pressure switch are either set too high, or the switch is bad. Check the rating for your switch, it's kick in (on) and kick out (off) pressures. If you have these values, you can set the switch yourself. Pump the pressure up to where you want it to kick out (off) and stop the compressor at that pressure by pulling the plug. Remove the contacts cover and adjust the spring until the contacts part, setting the contacts to the actual pressure. Drain the air down to below the kick in point. Replace the cap over the contacts, and turn the compressor back on. It should kick off at the pressure that you dialed in.
If the contacts will not set, or if there is too much carbon on the contacts, or if you note any burned wires or melted terminals, replace the switch. Minor carbon on the points can be removed with an emery board or fine sandpaper, and this should be regarded as a temporary fix.
Best regards, --W/D--
Feb 19, 2011 | Dewalt D55146 Factory Reconditioned 4.5...
What's with the warning label limiting the tank life to the year 2020? It seems to only be on Dewalt compressors.
I am thinking that like an underground gasoline storage tank or a BBQ grill propane tank, big brother has instituted a maximum life on the tank because it is pressurized.
Jun 22, 2010 | Dewalt D55146 Factory Reconditioned 4.5...
Won't go past 60 PSI
Return it as a valve is stuck / not seating.
Mar 05, 2010 | Dewalt D55146 Factory Reconditioned 4.5...
Tank pressure 120 regulated pressure 200. how can
If your pressure cut-off switch is faulty, it will keep running. Could be very dangerous. MSC has switches with different ranges. I had this problem once with an 80 gal. compressor. It was running and I cautiously walked over and shut it off. At this point it had 200psi built up. Yes, I was scared but a new regulator fixed it. The old contacts were rusty and wouldn't release. Hope this helps.
Terry
Nov 18, 2009 | Dewalt D55146 Factory Reconditioned 4.5...
Dewalt D55146 Factory Reconditioned 4.5 Gallon Electric Wheeled Portable Compressor, 1.8 Hp, 1750 Rpm Logo
563 people viewed this question
Top Dewalt Measuring Tools & Sensors Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vuk B
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
