HEWLETT-PACKARD Compaq 610 Notebook Logo
A
Anonymous Posted on Jan 31, 2013
Compaq 610 to hotspot
I have converted my Compaq 610 to Hotspot but my phone list doesn't shows its name. can anyone suggest what to do?
2 Related Answers
Anonymous
  • 6771 Answers
  • Posted on Jun 03, 2012
SOURCE: compaq 610 battery not charging, showing
The rechargeable battery needs to be replaced, go to www.ebay.com type make and model of laptop, refine search to battery.
Gerald Manuel
  • 564 Answers
  • Posted on Aug 02, 2012
SOURCE: How to find MAC address on my HP Elitebook 8460p?
use your command prompt and type ipconfig /all then look for physical address. that is your mac address.(To get to command window just press windows key and R then type cmd and press enter.)
My mobile hotspot connects to devices but no internet connection can anyone help me fix or solve this issue?
I use pda.net it works great even for phones where the data use is blocked. most providers will not let you use the internet so it has to be spoofed.
1helpful
2answers
Using my phone as mobile hotspot how do i get my network ssid.
You can use your Android phone as a portable hotspot and get your iPad, iPod Touch, or any other wireless device online. This is a great save when there are no available wireless connections available.
1. Go to the Home screen.
2. Select the Menu key.
3. Select Settings.
4. Select Wireless & networks.
5. Select Tethering & portable hotspot.
6. Select Portable Wi-Fi hotspot checkbox.
7. Select Portable Wi-Fi hotspot settings.
8. Select Configure Wi-Fi hotspot.
9. Input a Network SSID for your connection.
10. Select a security protocol. Options are Open and WPA2 PSK.
If you select WPA2 PSK, input a password for the connection and then select the Save button.
You will use the Portable Wi-Fi hotspot checkbox from above to enable and disable the connection. Once the connection is active, go to the device you wish to connect and configure its wireless connection to the Network SSID for you Android device and input the password (if you are using WPA2 PSK). You now have wireless access for your iPad, iPhone Touch, Zune HD, etc. anytime there is a cellular connection for your Android phone.
-regards and update me
Aug 08, 2014 • Cell Phones
Need password to use my phone off wiifi on my laptop
I have our laptop and xbox running off phones hotspot. what I did was go on your phone to the configure wifi hotspot. make sure u configure wifi hotspot first.it will ask for a network name, then password. I picked out my own then saved it.on my phone it shows phone wpa2 psk portable wifi hotspot. then u will click on wi fi hotspot should read portable hotspot phone active. now go to laptop look under the wireless internet should show a list of available networks. u should c the one u created on your phone click
O2 wifi hotspot no dns
The DNS info is provided via DHCP which is given out by the hotspot. You may want to A) try and simply reboot the phone and B) go into your settings > wireless and press and hold on the hotspot SSID (wireless name) and forget it. Then re-connect. Otherwise I would say it's an issue with the hotspot.
If you need to check any DNS query for website visit the site WhoisXY.com .
How do i get my sprint phone to work on wi-fi ?
sprint phone or samsung ?
Sprint offers high-speed WiFi service for existing Nextel customers, and provides an extensive network of hotspots in the United States at locations commonly frequented by business travelers, such as hotels, airports and conference centers.
Getting Sprint WiFi requires a Nextel customer account, connection-management software, a MyNextel user account and a computer that supports high-speed broadband.
Sprint WiFi plans include an unlimited WiFi hotspot and an unlimited PC access plan with a WiFi hotspot package.
Sign up for WiFi service through Nextel by calling 1-800-SPRINT1.
Download and install the Nextel Connection Manager software.
Nextel offers the WiFi version of the connection-management software at the Sprint Nextel website (see Resources).
Register your account via MyNextel on the Sprint Nextel website (see Below).
http://ortshop.sprint.com/en/solutions/dataaccess/connection_manager.shtml
Samsung Epic 4G Phone into a Wi-Fi Hotspot
The Samsung Epic 4G smart phone allows you to convert your phone into a Wi-Fi hotspot and connect up to five devices.
Such a set-up will keep you from running around searching for an area that offers free Wi-FI. If you're stuck in an airport or staying overnight at a hotel, you won't have to pay extra for Internet service.
You can connect your laptop or other media device to your phone's Wi-Fi network.
Press the "Home" button, which looks like the outline of a house, on the bottom of your Samsung Epic 4G phone.
Click the "Menu" button to the left of the "Home" button.
Click the "Settings" icon, which looks like a gray box with a spoke in the middle.
Scroll through the list and click "Wireless & Networks."
Press "4G" until a check mark appears, indicating the 4G network is enabled.
Click the "Home" button.
The 4G icon will appear to the left of your signal bars in the upper-right corner of your screen.
The separate sets of bars above the 4G logo indicate the strength of your 4G signal.
When the bars above the 4G logo are completely gray and the 4G logo is white, you have a weak signal.
When you are no longer receiving a 4G signal, your 4G logo will be gray and a 3G logo will appear, indicating that the 3G network is now enabled. If both of the logos disappear, you are not receiving any signal.
You must have either a 3G or a 4G signal to use your phone as a Wi-Fi hotspot.
Enable Sprint Hotspot
Press the "Applications" icon, a blue box with four whites squares in it, in the lower-right corner of your Samsung Epic 4G phone.
Press the "Sprint Hotspot" icon, which looks like a phone with two signal bars on the right side, until a check mark appears to the right of the icon, signaling the Spring hotspot function is enabled.
A pass-key allowing you to connect other devices to the phone's network will appear on the screen.
Write the pass-key down.
Enable Wi-Fi on your laptop or other device that you want to tether to your Samsung Epic 4G phone.
Search for the Wi-Fi network affiliated with your Samsung Epic 4G phone.
The name of the network will begin with "SPH-D700XXX."
To change the name of the Wi-Fi network affiliated with your Samsung Epic 4G phone, press the "Menu" button; the "Settings" icon; and "Device Name." Enter the new name for phone's Wi-Fi network.
Click the network affiliated with your Samsung Epic 4G phone on the device you want to tether to your phone'ss Wi-Fii network.
Enter the pass-key, and click "OK."
Your device will now be tethered to the Wi-Fi hotspot on your Samsung Epic 4G phone.
My hotspot on my iphone5 doesn't show icon for it anymore
if you are talking about turning on the personal hotspot, that is in settings. It is the 5th icon from the top. If you are talking about the two interlinked oval icon showing you that you have the personal hotspot active, you'll see that on the status bar at the top next to your 4g or LTE symbol when you are on the lock screen. If you are in your phone your status bar should be blue with the words "personal hotspot. 1 connection" or how many ever connection you have. If you are using a device to connect to your phones personal hotspot you'll get the interlinked oval icon in the top left corner.
1helpful
2answers
Wifi hotspot
Try to use this program to help you! My laptop can't turn on hotspot not long ago. And a friend sent me a program, which help me turn on WiFi hotspot on laptop!
Top 3 Ways to Create Build Set up Free Wi Fi Hotspot on Windows 10 8 1 8 7...
2helpful
2answers
Hotspot setup
OSToto Hotspot can create free WiFi hotspot on laptop with one click!
OSToto Hotspot former name 160WiFi
My web page doesn't load. What do i do? I tried restarting, deleting some files to make memory, but it still doesn't work. Pls help!
stanojevican,
please refer to below suggestions:
1) verify that you have a working internet connection
2) verify your access point/hotspot configuration
3) if you have several access points stored, verify that you are using the active hotspot
let me know if you need further assistance
2helpful
HOW CAN I SER GPRST SETTING IN MY SAMSUNG CHAMP DUOS GT-E2625W
Here's how to connect online using wifi on your phone:
  • Make sure you already are in a WiFi hotspot area.
  • Once you are in a wifi hotspot, Go to Menu option and then proceed to Wifi.
  • Switch on Wifi .
  • Automatically your phone will detect wifi
  • If doesn't show any wireless network , click search.
  • If no name appears WiFi hotspot, means you're less close to the hotspot or hotspot for WIFI
  • If there is, Just simpy choose the network and Click Connect.
  • After notice that the wifi connection is connected, open web browser or Opera Mini or chat applications such as eBuddy or Nimbuzz.
Thank you for using fixya..
Please rate me on fixya to continue my further assistance..
May 30, 2011 • Cell Phones
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
