Question about Konica Minolta DiMAGE Z6 Digital Camera
Camera shakes when turned on and when taking a picture there is a black area in upper left corner
I have a Dimage Z6. When I first turn it on the screen shakes and then settles? Also when I take a picture in wide lens there is a black image in the upper left hand corner. It goes away when taking up close shots.
    Genius:
  • 2,985 Answers
This soundfs like a Zoom lens element problem May be expensive to get fixed Check out customer support
Posted on Aug 01, 2007
SOURCE:
My dimage z6 was dropped
It has suffered mechanicaland electrical damage...er... BIN IT! seeing as Minolta are no longer inbusiness, and SONY now own their patents, and designs... you could try them but, its hardly worth it.... sorry!...
May 14, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
I dropped my camera
BIN IT!... :o( Minolta not exist anymore. SONY taken over. Try them if you really like the camera.
Apr 16, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Konica Minolta Dimage Damage
I had the same problem with mine, a minor fall cracked this, I disassembled the unit and one of the springs that hold the main sensor was broken, thus the sensor vibrates instead of "floating" when the camera is turned on. There are two possible solutions: The first is to get a faulty Z6 from eBay and get the parts (the main sensor assembly) and have it replaced. (If you are not comfortable working with 1mm screws, you'd better go with the parts to a camera repair shop and explain them the problem. The second solution is un-elegant but useful: If you disconnect the anti-shake circuit from the main board you won't have the annoying vibration at start, and the focus will work properly. I've done this and I am happy with the result (I rarely used the anti-shake feature, so I don't miss it). For reference, the anti-shake circuit ribbon is the one entering the mainboard just under the left side of the screen.
Ejoy.....
PS. if you have dark spots, chech that the sensor assembly is not too out of place or that a piece of the broken assembly is on the way. Realign it in place (and please don't touch it). and asseble tha camera back
Apr 05, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
My minolta dimage X20 whern turned on is all ready to take a picture but is only showin blackness, i can preview pictures etc and do every thing else My Minolta DiMAGE X20 is doing the same thing and has...
thats called "vigneting" and is caused by misalignment of the lens.... has it been dropped or mishandled? if so, it needs re calibrating and setting up by a pro camera technician.
Mar 04, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Konica Minolta DiMage Z5
The odds are you have a broken spring in the anti-shake assembly which has allowed the lens unit to shift to one side. The smudge you are seeing is the edge of the lens housing and will have a slight rounded shape. As you zoom in, you are extending the lens past this area so it no longer shows.
Feb 28, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
DiMage Z6 turns off when trying to view pictures
I posted this on another section:
My Z6 worked flawlessly for over a year, then suddenly started shutting off for no reason. Tried new batteries, etc. The problem turned out to be the memory card. My advice, buy a GOOD card instead of a new camera! Keep in mind, flash cards DO have a "life" to them - meaning they can only be used / erased so many times before they will cause errors (so don't buy a used card off of ebay - no matter HOW good the deal seems). If your shutdown problem started with a "unable to read card" warning, then its the card. The camera is actually "protecting" itself by shutting down. Good luck!
Nov 25, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Minolta Dimage X20
Check out the manual it needs a little setting up I guess. There should be a more comprehensive manual on the CD in PDF format.
Sep 22, 2007 | Konica Minolta DiMAGE X20 Digital Camera
Konica Minolta DiMAGE Z6 Digital Camera Logo
147 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
