Having trouble 2Wire 1800hg router and Vista connectivity issues; dropping internet. Any ideas?
  • lstepp Feb 01, 2009
    Thank you, tlagrassa. The problem is so random and varied I think we will end up buying a new router as well, as ours is old. But I will definitely try your good ideas before then. Thanks again.
  • 31 Answers
It could be a number of things. Most likely is interfearence. It could be caused by a router near your home that in using the same channel.Log into your router or use the 2wire control panel on your computer and change your channel to 11 or 1 .Also mixed mode wireless settings can be problematic.Try using 802.11b, 802.11g or 802.11n.   Another cause are 2.4 ghz cordless phones that use same frequency as the router.
Other things can wack it out as well like a microwave or if you are moving the notebook around the house the ductwork in your home could block the wireless signal.
I've had the same trouble for weeks. I broke down and bought a Belkin Wireless N router and had no trouble since.
Sorry for the long winded answer.
Posted on Feb 01, 2009
AT&T 2Wire 1800HG set up on Ubuntu
https://help.ubuntu.com/7.04/internet/C/connect-to-internet.html
Jan 03, 2010 | 2wire 1800HG Router (RG1800HG00)
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Ipod touch connection using 2 wire 1800HG
not sure if the 1800hg is the issue log into the router and turn off the encryption temporarily then try to connect the ipod. if the router connects double check your encryption key. if not or it connects for a second and then drops may be the internal security for the router stopping the connection you may have to call 2wire to help you turn off some of the security to keep the ipod connected.
Apr 08, 2009 | 2wire 1800HG Router (RG1800HG00)
2Wire 1800HG keeps losing connection
However as you said Desktop works fine and this seems to be issue with Wireless Netwrok card of your Laptop try to upgrade drivers of the Wireless netword card opf your laptop and this may possibly resolve the problem..
2wire 1800hg-- HomePNA stopped working
What you can do, is take the HPNA adapter from the back of the computer and plug the phone cable portion of it directly to the 1800hg's phone port. Since your 1800hg only has 1 phone port though it will not surf the internet, but this is a suggestion to try to make sure the inside wiring in your house is not bad. If you do this though your computer should say its connected, if it doesnt then it could be a driver issue or the phone cable in the HPNA adapter (try a new one then). If its the driver then try support.2wire.com for the regular usb drivers.
Jan 21, 2009 | 2wire HomePortal 1800HG Router...
1800 hg 2 wire wireless
1.can i use my 2wire 1800hg with vista?hooked up to ethernet connection.- yes its possible make sure you enable dhcp on your lan side of you router and under tcp/ip on your pc set it to authomatic assign IP address and dns server address. most router use 192.168.1.1 as thier default address to access it.
to fix your passkey problem.need to access the router and try to change the passkey then save and don't forget to restart the router after you save it,by unplugging it. "make sure your passkey is 8 characters long"
Nov 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Vista!!
Get rid of your PC and your troubles are gone. Invest in a MAC. The older iBooks and PowerBooks are a great investments and won't put a damper on your budget.
Jul 16, 2008 | 2wire 1800HG Router (RG1800HG00)
Replaced my old 2wire 1800HG with a new one and can't connect it
hi!
first of all, let's try to make the broadband link light turn green. open any browser, go the modem's UI by typing gateway.2wire.net or homeportal/setup on the address bar, follow the onscreen instructions on running the system setup wizard. it should make the broadband link green now. for wireless connection, click on the airport icon, and select on the SSID or network name in the drop down menu. if ssid is not on the drop down menu, click on other. type the SSID in the network name field and wireless security is none. (SSID is the last 3 nos. of the SN)
Apr 22, 2008 | 2wire 1800HG Router (RG1800HG00)
2Wire USB Remote NDIS Ethernet driver
There's only one driver listed at the bottom of the page.
Apr 16, 2008 | 2wire 1800HG Router (RG1800HG00)
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
