Question about GE PDS22SIS Bottom Freezer Refrigerator
Not working Clicking sound - no temperature display - no cooling actual model # PDS22SBSARSS but I can't find this on the GE website
  • 117 Answers
If the clicking sound is coming from the back of the refrigerator at the compressor, you have a faulty starting device or faulty compressor. The compressor has a 5 year warranty so call to have someone out if you can.
Posted on Feb 25, 2009
How do you work temp control on GE Profile top freezer
The ACTUAL TEMP light will come on and the display will show the actual temperature. To change the temperature, tap either the REFRIGERATOR or FREEZER pad until the desired temperature is displayed. To turn OFF cooling system, access SETTINGS from the HOME screen. Page over and tap COOLING SYSTEM ON.
Sep 22, 2017 | GE Refrigerators
GE PTS25SHSARSS refrigerator no longer cooling. Only four years old. Lights, fans (freezer circulating and compressor) work ok. Compressor comes on intermittently. Can set (adjust the display)...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | Refrigerators
Hello I have a GE lower freezer model # PDS22SBSARSS AND THE TEMP CONTROL is clicking and the digital readout is doing weird things by indicating wrong temperature and clicking, it stops after awhile...
Roll the refrig out and determine where the clicking noise is comming from. If it is form the small rectangular cover on back, replace the main board (WR55X10942) located under it. If the clicking is comming from the compressor area (at the very bottom, behind the cover which goes all the way across the bottom of the refrig) then replace the relay (WR07X10086) and overload (WR08X10061) located where the wires attach to the compressor, and for good measure, the capacitor (WR62X79 ). (located just to the left of the compressor)
Jan 12, 2011 | GE Profile PDS22MHR Bottom Freezer...
Refrigerator temperature control panel not lit. This happened last week but corrected itself....not sure how....but now display panel is off for good, it seems. Main Refrigerator lights are still working,...
Your Refrigerator Has a main controlboard located in the rear of the machine. This Controlboard sends power and reads the user information. if your user display (Temp Control panel) is not working it can only be 2 things The user display or the main controlboard.
As far a the refrigerator working without it, I would not trust it.
The clicking noise is a relay on the main control.
Usualy when I here this relay go on and off rapidly, there is a problem whith the main controlboard.
The big problem with this is why did the main control go out ? some other componet on the refrigerator could be the cause. A comon cause in the past has been the evaperator fan motor.
Jan 15, 2010 | Refrigerators
Ge profile bottom mount and temperature control
sounds like the mother board maybe bad. we replace alot of those , or 2nd i would say a display board .
Sep 13, 2009 | GE Profile PSW26P Stainless Steel Side by...
Clicking of Ge Model PDS22SBRBRSS; serial No; AHO45649
Replace the mother board. It is only a matter of time until you experience cooling issues.
May 26, 2009 | GE Profile PDS22MHR Bottom Freezer...
Temperature Display, Clicking Intermittent, Lost all Cooling
unplug the fridge and turn it around so you can see the compressor, does it have a capacitor located on the compressor (a round cylinder with wires comming out of it going to the compressor) it sounds like that could be your problem. They are pretty easy to change just a couple of wiers, just take note of where they go when you take it out. Make sure its unplugged from the wall before you do anything!
Feb 20, 2009 | Refrigerators
BLANK DISPLAY AND CLICKING SOUND
This is the main control board failing. My symptoms were identical (intermittent display and clicking), and eventually the clicking didn't go away and the freezer got hot. I replaced the main board yesterday and all is well (display fixed and no clicking). I was able to find the correct part number using the GE website (entered refrigerator model PD22S1S and then selected PDS22S1SARSS from the drop-down list). My part number was WR55X10656. The GE price was shown as $157.50, but I bought mine from ApplianceZone.com for $101.68. Hope this helps.
Dec 01, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
I HAVE A GE PROFILE FRIDGE, WITH BOTTOM FREEZER. THE DISPLAY WORKS SOMETIMES OTHER TIMES IT IS BLANK. ALSO EVERY NOW THEN I GET A CLICKING SOUND FROM THE COMPUTER BOARD IN THE BACK, SOMETIMES IT LAST FOR A...
This is the main control board failing. My symptoms were identical (intermittent display and clicking), and eventually the clicking didn't go away and the freezer got hot. I replaced the main board yesterday and all is well (display works and no clicking). I was able to find the correct part number using the GE website (entered refrigerator model PD22S1S and then selected PDS22S1SARSS from the drop-down list). My part number was WR55X10656. The GE price was shown as $157.50, but I bought mine from ApplianceZone.com for $101.68. Hope this helps.
My Fridge is less than 2 yrs old. Yesterday I heard a clunking sound coming from the fridge
to clunk,
i have a GE model PDS22SFSALSS & it did the same thing...blinking LED & clicking, then LED went blank. i read that GE was having major problems w/ the mother board, (cost for part $ 153.75 & $79.95 for service call, they couldn't tell me the labor cost!! )on many models & were re-calling some. i called GE repair 4/8/08, got no help, then i called customer service & gave them my model & serial #. they said my box would be fixed (mutha bd swapped) for free. i bought it 10/05, they came the next day & installed new board free! start w/ GE 1-800-432-2737 .....good luck
denden8148@aol.com
Nov 30, 2007 | GE PDS22SIS Bottom Freezer Refrigerator
Open Questions:
GE PDS22SIS Bottom Freezer Refrigerator Logo
370 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
