Question about Bosch Axxis WTL 5410 Electric Dryer
Won't dry My dryer is working but it goes from the first option to Damp and won't go any further. I can hear the barrel moving around inside but it's not getting hot in there. I've cleaned out the filter and the other component down below (washed out completely) so I'm not sure what the problem is. The manual says to clean the heat sensors but the ones inside the barrel are clean. There is no hot air coming out.
    President:
  • 331 Answers
Sana, this will sound trite, but did you check your breakers? The breakers for your dryer will be in the main panel, outside the house. There will be two breakers dedicated to this circuit, probably 40 amp. If one of these is tripped, the unit will tumble but not heat. If the breakers are OK, I'm sorry to say that this problem will require the services of a professional to diagnose. There are a series of safety thermostats and a thermister that electricity must flow through before reaching the element. If any ONE of these fails, the unit will not heat but will still tumble. Sorry I couldn't be of more help.
Posted on Aug 01, 2007
Whirlpool dryer won't turn on can hear
The switch you speak of is a mechanical switch with electrical contacts. If the spring inside gets rusty, it doesn't turn properly....replace it!
Dec 26, 2012 | Whirlpool Dryers
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
Aug 30, 2011 | Kenmore 74812 Gas Dryer
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
Won't dry clothes completely. They are still damp after a 60 min cycle
check you vent hose- if plugged/crimped air can't get out with moisture- also go to HOME DEPOT or LOWES- get dryer lint brush- goes in hole where lint screen is - clean out good
May 10, 2011 | Dryers
Dryer doesn't get hot enough to dry clothes
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this I fine then you’ll need to check the thermostat, igniter and coils. Also as its only 3 months old so it is recommended to use the warranty to avoid any further issues. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Samsung 7.3 Cu. Ft. 7-Cycle Gas Dryer -...
DUET DRYER WON'T DRY CLOTHES ALL THE WAY THRU -
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer sometimes dries sometimes not?
Hi, Have you checked the venting that goes outside. Most of the time, this helps especialy because it is electric dryer.
If I can help further, please let me know. Thanks
Vic
May 11, 2009 | Maytag Neptune MDG9700A Gas Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
95 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
