Question about Dayton (3E386) Heater
Dayton Salamander Heater - Blowing Unburnt Fuel/Smoke Randomly
Ok, got a Dayton 100K BTU salamander heater, ran great for a couple years. Nose cone got bright orange every time. After a while, the heater would be running fine, then the flame would go out and it would blow black smoke that smelled like straight up kerosene. This would be completely random. I took it in and they replaced EVERYTHING- the back cover, the air filter, fuel filter, lines, fan blades, spark plug. It ran a little better but was never cured. Well now it is worse than ever. It will blow smoke really bad, especially when you are kicking it on for the second time (still warm). Another thing to note, the nose cone is NEVER getting even remotely orange, and it is noticably not nearly as hot as it used to get. So I decided to try and troubleshoot... I took the cover off and ran the heater... ran great! Obviously not as much air was running into the combustion chamber, but it ran good and the nose cone even got about 1/3 orange! So then I start to put the top cover back on... halfway on it ran a little hotter... 3/4 the way on starts blowing smoke again. This would tell me TOO much air is getting pushed in? How is this possible? Ive tried messing with the screw adjustments on the back but nothing seems to change the issue. Any help would be appreciated since it has me and the local shop stumped.
-Brian
I have seen this before, you need to replace the nozzle.
Posted on Mar 03, 2011
Protemp heater is not running right and blowing black smoke before it kicks on
Sounds like you need a new nozzle and filter. Clean the pump strainer too.
Dec 09, 2013 | Milwaukee Tool Master Heater 70,000 BTU...
Comes on but cuts out and bellows smoke from filter.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 29, 2011 | Milwaukee Tool Master Heater 70,000 BTU...
Dayton 100K btu kerosene salamander heater - been running fine until last night. Unit is about 15 yrs. old. Ran for about an hour , then tripped out. I reset it and it would run for 1 - 2 min. and trip...
On that motor there should be a thermal overload to shut motor off in the event that it gets to hot. There also should be a start capacitor and if it is getting weak that could account for the unit tripping the breaker if it is trying to draw to many amps on start up. I would start by replacing the capacitor with plan to install new motor soon.
You may be able to extend the life of your motor some by giving it and fan a good cleaning, Good luck and thank you.
Jan 18, 2011 | Dayton (3E386) Heater
I have master torpedo multi fuel when its cold it work fine but when kick on after its hot it wont it just blows smoke out and have to unplug it
fuel pressure could too high you could have a cracked rubber hose on the pump sucking air start with fuel pressure and that will help us to get started
Dec 13, 2010 | Milwaukee Tool Master Heater 165,000 BTU...
Dayton 70,000 btu kerosene heater only runs consistently with 3/4 of a tank of fuel or more. Once it is below 3/4 it keeps shutting off. I have cleaned filters, tried to set pressure but pressure won't go...
If you can only get 4 psi from the pump then you have a problem with the rotor. This could be from the vanes not coming out properly of if you have replaced or serviced the rotor you may not have the clearance set properly between the pump ring and the top of the rotor.
Make sure to inspect the pump cover for any small cracks..
If you pump pressure in not enough the unit will not be able to pull fuel from the tank and you will see the burner cone slowly start to go from the orange color to a dark color and the unit will shut down.
Feb 10, 2010 | Dayton (3E386) Heater
No fuel to my torpedo heater
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Apr 02, 2009 | Milwaukee Tool Master Heater 70,000 BTU...
Where can I get a parts for a Dayton 55K salamander ????
Hello, go to this web site and they have the parts you need.
http://www.reddyparts.com/default.htm
Any more questions please ask. Good luck.
Jan 23, 2009 | Heating & Cooling
Unburned fuel coming from front nose cone when heating
in the back of the heater by the filter there should be a screw if yours is like mine screwing it in adds fuel backing it out gives you less make sure filtre is clean because if it isnt it will make it **** more fuel i took the cover off watched the ignitors and adjusted the fuel until it stoped making the jet sound and that is where i left it seems to be burning good there give it a try hope i helped
Jan 04, 2009 | Reddy Heater-30-55,000 BTU Variable
B115DT
Check the photo cell and its connections. Make sure it is clean and seated properly also.
Jan 24, 2008 | Milwaukee Tool Master Heater B115 Series...
Dayton (3E386) Heater Logo
790 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
