Gmp075-3 Indicator still flashing 1 after circuit board replaced
Posted by cmason236 on Jan 31, 2009 My GMPO75-3 is locking out with a flash indicator of 1. I have had the circuit board replaced, the sensor cleaned, and a new filter put in. It worked for a week perfectly fine. Since then about every 24 to 48 hours it locks out again flashing a 1. The little gold ignitor comes on but the blue flames don't start. If I reset the circuit board the heat starts right away.
  • cmason236 Feb 21, 2009
    Thats for your advise. A strange thing has happened. The new board failed three times flashing 1 and has not failed since. It has now been a month.
    Do you think it needed to time to reset or adjust?
  • Pyldrvr May 11, 2010
    Sounds as though you may have a bad connection on the board or bad solder conection on the board. I board is not older than a year it should still be under warranty..hope this helps
  • 478 Answers
Replace the gas valve. If you getting 24vac at the gas valve and it fails to open. Firist check all wiring connectors.
Posted on Mar 28, 2009
I have a fiat dobblo my right indicator works fine but my left flashes quickly and they both come on together and they are low
Make sure that all the indicator bulbs on the left is working. Is one of them isn't going on, the rest on the left hand side will flash faster. If you had one of your indicator bulbs replaced recently? The circuit on the indicators have a certain resistance. If one bulb goes faulty. Or replaced by an aftermarket it will behave like that.
Jan 30, 2017 | Fiat Cars & Trucks
Sony Cybershot DSC-W55 Flash Error Code
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Mar 24, 2008 | Cameras
How do I fix a LG flat screen TV?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Feb 01, 2016 | LG Televison & Video
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
2001 F-150 cruise control stopped working. Already checked the fuse and it's good. What's next
really tough to do on the net but first we need to know about any codes...
Hold speed control OFF button, and turn ignition switch to RUN position. CRUISE indicator should flash once to indicate successful entry into self-diagnostic mode. If CRUISE indicator does not flash, start procedure over. If CRUISE indicator still does not flash, repair system by symptom there might be some switch concern
If CRUISE CONTROL indicator flashes once followed by 5 additional flashes, replace speed control servo/actuator.
Release speed control OFF button. Within 5 seconds in entering self-diagnostics, press speed control ON button. Press remaining speed control buttons in the following sequence; ON, RES, COAST and SET/ACCEL.
As each button is pressed, CRUISE indicator will flash.
Wait until indicator light goes out, then press next button. After sequence has been completed, indicator light will flash to indicate test passed or failed. With the codes we can then better diagnose your concern
Immediately after static test has passed, actuator performs a dynamic test by automatically operating throttle .04-.40" (1-10 mm). Observe throttle movement to witness any sticking in cable or linkage. Ensure throttle returns properly. Turn ignition switch to LOCK position. If self-diagnostics do not pinpoint fault there is more we can do but tough over the net
Mar 26, 2010 | 2001 Ford F150 Styleside SuperCrew
Projector epson emp-30 in error
i have one that work but there are red bars on the display, for sale 50.00 no lamp
Mar 22, 2009 | Epson EMP 30 Multimedia Projector
Sony KP-53V80 is not turning on.
4 LED flashes indicated a faulty IC board
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
Indicator light flashing red.
You have a shorted circuit board inside the TV, have it repaired.
Jul 06, 2017 | Panasonic PT-50LC13 50" Rear Projection...
Green indicator light flicks about 3-5 times
The power supply has likely detected a short circuit. Hold the front panel INPUT and MENU buttons down for 5 seconds then read the code from the green light. If the light flashes a 2-2 code (2 flashes, followed by a 1/2 second pause, followed by 2 flashes) then pico fuses are blown. A 1-2 code indicates that nothing is wrong. The likely cause for blown pico fuses (FA904 & FA905) is a bad convergence driver IC. The PC board must be resoldered to replace the ICs and fuses.
Aug 09, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Sceptre X7G nagaVI problem
For most of the problems above you will find it is bad capacitors on the power board sending unstable power accross to the controller board.
For the last posted problem (Comment by Guest, posted on Jan 02, 2008) you have a dodgy inverter circuit that needs to be repaired.
Both faults should be fairly cheap to have taken care of at your local TV repair shop. You may need to call a few in your area not just for a quote, but also to see if they are willing to work on an LCD monitor.
Hope that helps you all =)
Dec 21, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
