FixYa.com
Tags:
Brother DCP-115C All-In-One InkJet Printer
Brother dcp115 c machine error af
posted by pmed on Jul 31, 2007
scanner unit does not find home position . Its kinda jittery , well it did hav a ink spill so i cleaned all i cud in a strip down. the main board did not seem affected so i take it it must be a home position fault on the scanner unit.
wot u think
Comment by pmed, posted on Aug 07, 2007
Did that as u said But the fault seems similar to that of the HP 6110 with "scanner failure" .
where is the scanner home position sensor located.it just says "failed to init" & sounds as if the scannermotor is gonna strip a gear.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 06, 2007
Thanks for Trying (70)
CanDo
Rank:Wiz Wiz
Rating: 76%, 111 votes
Any type moisture on a printer can cause many problems especially a malfunction and possibly destroyed your whole printer. It will need to be cleaned very well in every area of the spill. Rollers, gears, shafts, surfaces must be clean for printer to function properly.
Could possibly have to uninstall all printer software drivers and reinstall them restarting your machines.
Rating Locked! (?) pmed has rated this solution as Thanks for Trying
Can you Help with these Printers problems?
printer still wont work...
I recently contacted you online... Answer This...
Helppppppppppppppppppppppppp
Hello, will somebody kind... Answer This...
printer problem
there is a rotating sound upon... Answer This...
toubleshooting
the red light keeps blinking... Answer This...
Brother 115C printer says no...
I purchased two brother 115c... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
