Question about Kenmore 62602 Electric Dryer
Drum does not rotate
Motor runsand the dryer is hot
  • 10,865 Answers
The drum rotates due to a belt that goes around the drum and is driven by a small motor. The most likely answer is that the belt broke. This a common problem on an older dryer. It is relatively easy to replace the belt.
Posted on Feb 01, 2009
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
I have a speed queen dryer and all it does is hums and instantly has a burning/hot smell. Any help would be great, thanks.
Hello James,
If you can rotate the dryer drum easily by opening the door and rotating by one of the drum baffles and it rotates easy and noise free,the problem is going to do a bad motor
Gene
Aug 08, 2011 | Amana NDE7800AY Electric Dryer
The dryer drum does not rotate. I have a Kenmore electric model number 110.62622101. It blows hot air but drum does not rotate
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 15, 2011 | Kenmore 62622 Electric Dryer
The motore will run, but it is not spinning. The motor smells hot when it is running and not spinning.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt.
Here is a link to the belt.
Jan 06, 2011 | Amana ALE443RAW Gas Dryer
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
The dryer gets hot but the drum does not turn
sir please check the motor is running and this will be fixed inside the dryer and a belt will be fixed which makes the drum to rotate when the motor starts.so you should check both the belt and the motor.
Sep 04, 2009 | Hotpoint Aquarius WD640 Front Load...
My drum won't turn at all...
check the belt and tensioner if they are good motor is probably bad.
Jul 25, 2009 | Maytag Neptune MCE8000AY Electric Dryer
TD 4112W Dryer does not auto reverse
my new dryer makes athumping sound when in use and it sounds like a pair tennis shoes are being dried
Feb 16, 2009 | Zanussi TD4112W Electric Dryer
The dryer just makes a humming noise when I turn it on, but won't turn all the way on
When you say it won't turn all the way on, does that mean the drum isn't rotating?
If yes, the belt from the motor that goes around the drum might have broken and you can hear the hum of the motor spinning but no longer rotating the drum.
The other thing I can think of is that the motor itself has failed, possibly seized, and you can hear the motor trying to spin but it cannot. With the dryer unplugged and empty of clothes, try to rotate the drum. If it rotates extreamly easily, then the belt has broken. If you cannot rotate it at all by hand, then chances are the motor is seized. It should rotate with moderate effort.
Mar 08, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
67 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
