Question about Hitachi 43GX01B 43" Rear Projection Television
Akai pth5488 54 inch rear projection television
The picture has red and green ghosts. The tv is almost 5 years old and off warranty. I checked the manual that came with the tv and tried to adjust the convergence but I have no idea what I am doing and it is not working. Someone suggested I clean the rear projection lenses and I have no idea what or where they are. Please help me.
  • jrdad Dec 12, 2008
    it sounds like my 43" is doing the same thing, except it smelled like something was burning and the screen would do a fizzle effect. any ideas?
    President:
  • 4,402 Answers
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.eserviceinfo.com/
http://www.digitalhome.ca/forum/search.php
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
SOURCE:
Akai pt4298hd 42 inch projection tv has red and green haze.part number stk392-040 were replaced 2 years ago.that fixed the problems.the symptons are the same.are these chips easy to acces ?
Yes they are But CK 2 resistors 2.7ohms in front of ICs if they are Bad they can cause same Problem to order new ICs $9.50 each Call Mats Electronics
1-800-628-1118
Dec 20, 2009 | Akai PT4298HD Rear Projection Television
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Jan 25, 2008 | Televison & Video
TV went out and will not come back on. Power light shows red but no sound or picture. It's about 4-5 years old.
I have a akai tv, the tv went out but won't come back on. i'm still getting a red light but the tv just beep when I press the power button.
Sep 18, 2009 | Akai PT4799HD Rear Projection Television
Ghosting of the image
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
GB4308 Ghosting
The cost I don't know, but this can be fixed. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Jan 02, 2009 | Apex Digital GB4308 43" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Ghosting in red ,blue & green
Sounds like an allinment problem with the color projection you can allin yourself via small screws on color tubes in rear. but be careful as tv needs to be on to do it.
Jul 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
Hitachi 43GX01B 43" Rear Projection Television Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
