Question about Bike Extreme Lite Youth Shoulder Pad
1980 sportster tappet settings
Does anyone know how to set tappets on a Harley Davidson 1980 XLH 1000cc? Also what are the clearances?
  • 23 Answers
Hydrolic: Set the tappet at its lowest point by rolling the rear wheel with the bike in gear (on a stand of course.) Adjust the push rod until there is no shake. Load the tappet 4 full turns. The push rod will be tight. Wait at least 15 minutes before moving to the next one to allow the pressure to dissapate. Don't want to bend a pushrod or valve. Repeat for all 4 push rods.
Solids: Same as above but push rod should spin freely without any up/down slop. No need to wait for the bleed off. Go right on to the next one.
Posted on Aug 20, 2009
Is it worth rebuilding the top end of a 1980 Sportster?
Hi, Randy that all depends on its overall condition, whether or not you or a shop/dealer are going to do the work and how much "DRACHMA" you have in your wallet, in excellent condition the bike can sell for $8,000 depending on your zip code for more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
1980 Harley Davidson XLH SPORTSTER 1000cc Standard Equipment Prices Specs
https://www.carlsalter.com/pdfs/Harley-davidson-1970-78%20XL%20Service%20manual.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak to me personally absolutely "FREE"
May 11, 2017 | Harley Davidson XL 1200 C Sportster Custom...
Is there an alarm system for 1997 xlh 1200 sporster
http://www.jpcycles.com/1980-harley-davidson-sportster-1000-electric-start-xlh1000/digital-guard-dawg/locks-and-alarms/exact-fit
might find one here
Mar 27, 2013 | Maisto Harley Davidson 1997 XLH Sportster...
Set timing on 1980 harly sportster
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
Installing an Accel Ignition system in your old Big Twin Harley
Sep 23, 2012 | 1979 Harley Davidson XLH 1000 Sportster
1979 Harley Davidson Cam Adjustment 1000CC
Hi Chris, for more information about your question please visit the website below. Good luck and have nice day.
picture of 1979 xlh 1000 cam timing marks Google Search
Oct 13, 2011 | 1979 Harley Davidson XLH 1000 Sportster
1979 Harley Davidson 1000CC Sportster Shovelhead cam set-up
Repair Manuals Online
The Internet, though, has a large number of web sites where you can buy service manuals and schematics from bookstores, publishers, and other collectors. Here is just a sampling of what sites are out there:
http://www.clymer.com/
http://www.haynes.com
https://www.howtomotorcyclerepair.com/
Oct 12, 2011 | 1979 Harley Davidson XLH 1000 Sportster
Can anyone help me find a wiring diagram for a 73 harley sportster xlh 1000cc
Most Ironhead sprotsters were pretty close as to the wiring. If you'll contact me directly, I'll scan a diagram for a '79 in and send it to you. Contact me directly at wd4ity at bellsouth.net. Good Luck, Steve
Apr 30, 2010 | Harley Davidson XLH 1000 Sportster...
Adjustment on 1000cc values 1983 harley davidson sportster
To adjust the valves on your Ironhead Sportster, first collapse all the pushrod tubes, remove the spark plugs, and get the rear wheel off the ground. Put the transmission in fourth gear. Now, use the rear wheel to turn the engine.
To adjust the valves, bring the front cylinder to Top Dead Center. Use a common plastic drinking straw down in the spark plug hole to make sure the piston is at Top Center. Make sure both tappets for the front cylinder are all the way down. Now, loosen the lock nut slightly and turn the adjuster to make the tappet longer. You want to make it just long enough so that you can't turn it with your fingers. Gradually back down on the tappet until you can turn the pushrod with your fingers. Lock the locknut down when done. Now do the other tappet.
Once you've done the front cylinder, turn the engine using the rear wheel until the rear piston comes to Top Center. Always turn the engine in the normal direction of rotation. Adjust the two tappet the same way as you did the front cylinder tappets.
When finished, put the transmission in neutral, lower the rear wheel, put the plugs back in, and close up the pushrod tubes.
These tappets set to Zero Backlash, none. Therefore this must be done on a completely cold engine. When the engine starts up and as it warms up, the cylinders and head "grow" due to the heat expansion properties of the metal. As they grow, you pick up valve lash and the valves will clatter a bit. This is where the old saying came from, "You can tell it's a Harley from a mile away by the way the engine sounds. You can tell it's an Ironhead from a half mile away from the valve clatter". If you get the valves too tight, when the weather cools down in the winter, you could wind up with a valve standing open just enough to make the bike impossible to start due to low starting compression. It's better to have the valves a bit loose and have them clatter than have them too tight making the engine difficult to start.
Good Luck,
Steve
Apr 24, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Valve tappet adjustment
well, I can see ur message has been here for quite some time. Most probably you got the answer to ur request.
I just did the valve clearance on the engine of my SJ413 that has the 1000cc engine of an SJ410 :
When cold: 0.13mm Intake and 0.18mm Exhaust
Engine sounded well and worked fine after that.
Enjoy
Mehdi
Nov 18, 2008 | 1986 Suzuki Samurai
Bike Extreme Lite Youth Shoulder Pad Logo
128 people viewed this question
Top Bike Sport & Outdoor - Others Experts
Are you a Bike Sport and Outdoor - Other Expert? Answer questions, earn points and help others
