As soon as start the car the oil icon appears then leaves but the motor icon stay light and also get message perform service soon what does it mean.?
SOURCE: Reset service engine soon light
You can take the car back to Mercedes Benz they should reset the oil change light and get all the radio codes for you for free. They don't suppose to charge you!!!!
SOURCE: SERVICE ENGINE SOON LIGHT CAME ON YET MY CAR DOESNT MAKE ANY FUNNY NOISES
THE OIL CHANGE INDICATOR WILL NOT CAUSE THE SES LIGHT TO COME ON.THEY MAY HAVE LEFT SOMETHING DISCONNETED NEAR THE AIR CLEANER HOUSING WHEN CHECKING THE FILTER.IF NOT HAVE CODE READ(SHOP/PARTS STORE)
SOURCE: VW POLO 1.6 2002 classic
I have already a solution to my problem. Remember, when I posted, that my 1997 VW Polo Classic, that it won't start even it has sparks coming from the "spark plugs" and the timing was set already. Yesterday, My mechanic was puzzled, why the intake manifold has a very low pressure. Just this morning when he opened. It was clogged with "tartar" like material. It includes the valve & piston. Therefore, it is impossible to have combustion. Because, it lacks the fuel & air even how much sparks is present. I hope this could help to VW cars owners having the same trouble.
SOURCE: Lights that wont go away: Trac Off, ABS, Oil Change, Service Vehicle soon
I have this same problem with my 2000 Grand Am and the mechanic that I had taken it to had told me it was from a bad ABS sensor in a wheel hub, in order to fix that I would need to purchase a new hub. He said that triggered the service vehicle soon light and had caused the ABS light to come on as well. Although I have not fixed it yet, I trust that this is the problem.
SOURCE: service engine soon, TCS off, SLIP
The oil change wouldn't cause this problem. Just in-case, check the engine oil level.
There are many emission sensors in the car that will make the engine light come ON. Best way to find out what's going on is to have an auto-parts store hook up a engine code reader and tell you what the code means. Most auto-part store will do this for free.
Testimonial: "very helpful. i have the mechanic checked the car , the sensor says it has a malfunction in P0340"
