Question about Kenmore Elite 45986 Front Load Washer
Front Load Washer moving around because of the high rpm
My washer moves around during the spinning cycle because of the high rpms of the spinning cycle. Can you sugggest a way to keep it stable?
  • 640 Answers
If you dont have a weak floor just lock the legs,,,on the legs theres a nut on each leg..your unit came with a little wrench..that fits theses nuts,,,now you have to put unit on spin ,,when you get in highest or fastest spin ..adjust leg nuts than thighten them one at a time all the way up to the base of unit,,you might have to spin on high speed twice ..you will see when unit becomes steady...this wont work as well if you have a wooden floor or a weak floor..onthejob
Posted on Feb 02, 2009
Ftf530es knocks during spin cycle
Good Afternoon Amy,
I understand that your Frigidaire washer, model# FTF530ES, knocks during the spin cycle. I also see that the drum moves from front to back and not up and down. I suggest making sure that your washer is level from front to back, side to side, and from corner to corner. If after leveling you washer, the drum is still moving from front to back, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why the drum is moving from front to back. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FTF530FS Front Load Washer
Washer won't spin on spin cycle but spins during other cyles
Hello rylee1966 - From what you are describing, it sounds like the washer agitates, but it will not enter a high speed spin. If that is correct, more than likely there is a door switch failure. I will personally recommend contacting a professional to move forward accurately and to assist with the repair(s).
Feb 23, 2013 | Frigidaire Affinity ATF7000E Front Load...
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer moving around during spin cycle
adjust the load, seriously,, you have more weight on one side than the other which causes an uneven load and at the higher RPM's it makes the machine bounce around
May 29, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My washer is off balance during the spin cycle it jumps, and moves around
With the washer empty, tilt it front a few inches and drop it back down. This will re-level the legs. If it still jumps around, replace the drum snubber, inside the front of the machine. It's a rubber pad that keeps the drum from moving around too much. Snubbers dry out with age.
May 07, 2011 | LG WM-2277HW Front Load Washer
Washer is convulsing and moving around during
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | GE WSXH208A Front Load Washer
How do you keep washer from jumping around during spin cycle? The washer is on one of the Maytag storage stands. It is leveled on a concrete floor but jumps around when on medium or high spin cycle. Any...
first of all if this is a new washer you need to make sure all the shipping straps or bolts are off. one way to find out is to open the door reach and grab on to the tub it supposed to be able to move up down and side to side. if not then the shipping bolts has not been removed.
Nov 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Amana Front Load Washer moving during spincycle
what is the model # it may be for example, LAT9206BAE
May 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
98 people viewed this question
Sal De
fordexpert
Robert Rankin
