Question about Sony Ericsson K750
New housing for k750i
I just got the dark blue full housing fascia for my k750i installed it all as per instructions, now i cant get a network, what have i done wrong
  • Nicola Lee
    Nicola Lee Jul 31, 2007
    done that 3 times, thanks anyway
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
Take it off and RECHeck all the little connections you might of bumped!
Posted on Jul 31, 2007
  • scott gregg
    scott gregg Jul 31, 2007
    will it work right if you put the old housing back on? IM trying, im trying!!! more info if youve got
How do I replace my rear bumper on my 04 pacifica
  1. Open liftgate.
133387935 Fig. 12
  1. Remove two push pin fasteners per side at the liftgate tower area (Fig. 12).
  2. Hoist and support vehicle with safety stands, as necessary.
133387936 Fig. 13
  1. Disconnect the park assist wire connector under the vehicle and the push pin fasteners attaching wire harness under the vehicle (Fig. 13)
  2. Remove the four push pin fasteners attaching rear fascia to reinforcement bumper.
  3. Remove two screws (each side) attaching fascia to rear fascia bracket in the wheelhouse.
  4. Remove the screw on each side attaching the upper fascia in the tail lamp bucket area.
  5. Remove rear fascia from vehicle by lifting sides of fascia up and outboard to release from rear fascia brackets.
  6. Place fascia on a clean surface.
133387937 Fig. 14
  1. Remove park assist sensors, if necessary (Fig. 14).
133387938 Fig. 15
  1. Remove spring clips attaching upper and lower fascia together (Fig. 15).
  2. Using a trim stick release locking tabs and separate the upper and lower fascia.
133387939 Fig. 16
133387940 Fig. 17
  1. Remove move the bright chrome molding from the upper fascia (Fig. 16). Using a trim stick, starting at the out edge of the fascia release the locking tabs (Fig. 17). Grip the molding and pull outward from the fascia while releasing the locking tabs.
  2. Remove molding from fascia.
INSTALLATION
  1. Place bright chrome molding in position on the upper fascia.
Jan 06, 2012 | 2004 Chrysler Pacifica
Can i put a k750i housing/fascia onto a w810i?
yes you can change the back only because the k750 has a joy stick which is different from the w810
Jan 11, 2010 | Sony Ericsson Walkman W810i Cellular Phone
How do you remove the air filter box on a 2001
REMOVAL
Release hood latch and open hood.
Access Rubber Grommet
Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners.
Fastener Locations
Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield.
Remove Push In Fasteners
Remove the push pins attaching the fascia to the upper radiator closure panel.
Headlamp Jack screws
Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s).
Roll Fascia Forward
Roll fascia forward to clear way for headlamp housing removal.
Disconnect wire connector from back of lamp socket(s) and/or bulbs.
Remove Headlamp Housing
INSTALLATION
CAUTION : Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
Place headlamp housing into position.
Connect wire connector to lamp socket(s)
Verify headlamp and signal lamp operation.
Install jackscrews to attach headlamp housing to crossmember.
Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
Install nut on fascia stud through the splash shield access hole.
Verify headlamp operation and alignment
Nov 03, 2009 | 2001 Chrysler 300M
Sony ericsson k750i want to share the internet connection
if you use windows xp, go to network connections and start Network Setup Wizard and choose the appropriate options.
Apr 10, 2009 | Sony Ericsson K750i Cellular Phone
How do you replace headlamp bulbs on 1999 chrysler 300
You half to remove the Headlamp housing to change it. Here is the instructions out of the factory manual.
Tell me if this works for you?
HEADLAMP HOUSING - CONCORDE/LHS/330M Headlamp lens fogging is a normal condition and does not require service unless excessive or continual. Moisture will vent from tubes or vents located on the back of the lamp.
REMOVAL
  1. Release hood latch and open hood.
  2. Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners Access Rubber Grommet
  3. Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield Fastener Locations
  4. Remove the push pins attaching the fascia to the upper radiator closure panel Remove Push In Fasteners
  5. Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s) Headlamp Jackscrews
  6. Roll fascia forward to clear way for headlamp housing removal Roll Fascia Forward
  7. Disconnect wire connector from back of lamp socket(s) and/or bulbs.
  8. Remove headlamp housing Remove Headlamp Housing
INSTALLATION CAUTION: Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
  1. Place headlamp housing into position.
  2. Connect wire connector to lamp socket(s) and/or bulbs.
  3. Verify headlamp and signal lamp operation.
  4. Install jackscrews to attach headlamp housing to crossmember.
  5. Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
  6. Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
  7. Install nut on fascia stud through the splash shield access hole.
  8. Verify headlamp operation and alignment
Mar 27, 2009 | 1999 Chrysler 300M
I need instructions to replace fascia housing for my K1
Why do you not take the mobile to a repair center and have them replace it for you.
Jun 06, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Sony Ericsson K750i-seems to be blocked
phones when you buy a phone from a mobile provider it is locked to there network as always.....that is why we unlock them to use them with other carriers out there.
What you can do is take the phone to a mobile service center and have them unlock the phone for you if it is lock.
Apr 10, 2008 | Sony Ericsson K750i Cellular Phone
Nokia 7373 fascias
KEZ123 - you need a T6 screw driver to undo the screws
GUEST - take the phone to a mobile repair center and have them replaced the housing for you.
Jan 29, 2008 | Nokia 7373 Cellular Phone
7373 fascia
well, this phone sint made to change the fascia, in english, you cant change the fascia like a 6230 etc, BUT never fear!!, just type in ebay "7373 fascia" and someone may give you a housing for it, this will require you to unscrew the phone and do it manually, so i suggest you watch out, but everybody learns the hard way!
hope this helps!
Dec 08, 2007 | Nokia 7373 Cellular Phone
Sony Ericsson K750 Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
