Question about Apple iPhone Smartphone
My iphone is only available to make emergency call,Waht can i do?
Its show that iam connected to ITUNES and the only thing that i can do is make emergency calls.Please help with this situation,also my iphone is connected to T-Mobile.What can i do to fix my Phone.Thanks in advance.
  • 2 more comments
  • Anonymous Feb 14, 2009
    Iphone
  • snooby_ad9 Feb 21, 2009
    My iphone is only available to make emergency call,Waht can i do? Its show that iam connected to ITUNES and the only thing that i can do is make emergency, and it asked me to insert iphone sim card. ???
  • spongebob828 May 11, 2010
    how to unlock iphone when you have forgotten the password pleaseeeeee helpp!!!!
  • Kathleen Bota
    Kathleen Bota May 11, 2010
    hi ariel...
    just a few questions...
    is this the 2G or 3G?
    did you buy the phone unlocked, or have you at any time had to unlock it?
    and have you recently upgraded the firmware for your phone in iTunes?
Posted on Nov 24, 2009
If it gives you a screen that says you have 7458978965456 Minutes before you can use this phone then simply Hold the top Power button and the Center Home button until it shows you the screen that has the usb and itunes icons. Then go to itunes it will say this iPhone is in recovery mode, then click the button that says restore this iphone. Once that is all done you can go ahead and re-jailbreak your phone with Quickpwn or whichever program you find suitable. Good luck.
Posted on Feb 03, 2009
My iphone is disabled and says connect to itunes it will only allow me to make emergency calls
When the Iphone is restored to factory settings you will receive the prompt to connect to itunes and only make emergency calls, you will need to connect the Iphone to itunes to allow the Iphone to complete the setup process, similar to when you first buy an Iphone.
Mar 24, 2011 | Apple iPhone 3G
Iphone will not start properly
did you get a solution to this as i am having the same problem
Jul 25, 2010 | BoxWave Corporation Apple iPhone 2G...
MY IPHONE IS LOCKED HOW CAN I UNLOCK IT.WHILE IAM COPYING ITUNES TO MY PHONE IT IS LOCKED.ON SCREEN IAM GETTING ONLY THE EMERGENCY CALL KEY PAD AND NOTHING IS THERE.IAM NOT ABLE TO OPEN THE MAIN MENU
Your phone is not activated, you have to activate it or jailbreak it. Please give me your firmware details so that I can help you with jail breaking.
May 30, 2010 | Apple iPhone 3G
Hi, having a problem in connecting to itunes. itunes is unable to read my 2G iphone. current phone status shows the cable and unable to activate/unlock my phone. its in the emergency call status. can...
if it could make calls just download blackrain and jailbreak it if u like,, thats means yr phone is in dfu mode or uninstall itunes then reinstall it n connect
Apr 29, 2010 | Apple iPhone Smartphone
Apple iphone 1st generation
That is DFU mode. It's there for software upgrading/downgrading. If you can't get out of this mode, reloading the firmware from Itunes will release it.
Open up Itunes.
Connect your IPhone.
Select your IPhone in the left window frame.
Press the "Check for Updates" button located in the summary frame.
Click "Download and Install."
Don't disconnect it while it's doing it's thing.
Once it finishes you will be out of DFU mode.
Hope this helps,
BReady
Mar 28, 2010 | Apple For Iphone 1st Generation White...
Dec 26, 2009 | Apple iPhone 3G
3GS only allows emergency calls
you will need to do a forced restore on iphone to resovle the iphone passcode lost problem. but when you do a forced restore on iphone, you will wipe all content from the iphone. To do a forced restore hold the HOME button, then connect to the USB cable and continue holding for a LONG time (a minute or more). Once iTunes responds release the button and your iphone will be restored.
or you can try to plug it into iTunes with it at the unlock screen. Somewhere it should say “Unlock your iPhone” or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click “Restore”. Restore it as a new device (not from back up) in iTunes. After that, you can just sync your media and apps back onto it.
Sep 25, 2009 | Apple iPhone Smartphone
Iphone disabled to "connect to itunes" but needs passcode
Turn your phone off and plug it into your computer holding the home button down. That will put your phone into restore mode.
http://www.mobileease.co.uk
Jul 13, 2009 | Apple iPhone 3G
IPhone 3G Error 0xE8000001
Where did you purchase your phone? however, you first need to update itunes to 8.0.2, that might solve your problem. Unless you have an unlocked phone then restoring your phone is useless because when you restore an iphone with itunes in the US without an att sim card it will actually lock the phone, but I do not think that is your issue. the two things you are seeing the connect to itunes and the emergency call system means that your phone is not properly activated. which is done by connecting it to itunes.
Jan 20, 2009 | Apple iPhone 3G
IPhone Disabled
put it in restore mode hold the power and home menu button for a little and plug it in to itunes when it shows the connect to itunes pic and then press restore if ur iPhone is unlocked u hv to inlock it again!!!
Jun 02, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
2,644 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
