Question about Dell Inspiron 2200 Notebook
Dell inspiron 2200 - screen is black
My laptop was not charging right and I noticed the plug wasn't sitting tightly, so I bought a new charger. The day I got it, I plugged it in and it started to charge. I turned it on and it loaded up fine, all icons and everything. I turned it off and let it sit a few hours to finish charging. When I turned it back on, it started to boot up and then the screen turned pitch black. I turned it off, and on again, but still black. What might cause this? Is this something I can try to fix myself? Or can have fixed at a decent price? I'm not sure if the charger is just a coincedence or if it caused a short or something. I don't know much about computers. I've had it a few years, not sure the avg life span on one of these, but it's always worked well for the web surfing I use it for so I'm hoping fixing is an option rather than pitching it. Thanks in advance if you can help me.
    Champion:
  • 219 Answers
Sounds like your graphics card has died on ya. If it is on board graphics with no expansion slots for a card you'll have to get another motherboard. If it has expansion slots for graphics you could find out what is compatible and buy one. as far as installation. I would have someone with knowledge about these things to install it...Hope this helps
Posted on Feb 01, 2009
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell Won't Regonize New Dell Battery
Hi
Need more info
We are talking about the main battery / not cmos battery?
Does charger lamp illuminate?
If so ensure plugs are securely pressed in to Laptop and charger.
If charger lamp does NOT light up try a different wall plug.
Surely Dell would have tested that battery and charging before returning.
Aug 12, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron E1505 won't charge or power on period!!!
Sounds like you might have a bad dc power jack. ifyou wiggle the jack around where it plugs in on the computer, does the powr light come on?
Mar 30, 2009 | Dell Inspiron E1505 Notebook
Dell Laptop Charger, wont charge bat. but keeps computer running.
Dell has cheap chargers, the wire snapped on the inside underneath the rubber. My ex boyfriends charger had the same thing happen. You need to buy a totally new charger .
Jan 21, 2009 | Dell Latitude D531 Laptop Computer PC...
Dell Inspiron 2200 has been working fine, But now won't turn on.
1. Try and check the voltage output of your adapter using any ordinary voltmeter. It should have a voltage reading close to the dc rating printed at the back of your laptop.
2. Even if you have problem with battery, the laptop should power on. Otherwise, if both battery and charger is working fine, then there is a problem with the charging circuit that is built-in on the laptop's mainboard.
If charger is defective, then its more practical to buy a new one instead of sending it or repair. Repaired chargers can cause more problem for you in the future.
Nov 15, 2008 | Dell Inspiron 2200 PC Notebook
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
Dell inspiron 2200 is not powering up after being switched on, its on black screen! help
The most probable cause of failure is the memory sticks on the computer. Follow the troubleshooting steps given below and you would be able to get the system up
http://tinyurl.com/5gmvww
Thanks
Proton
Donot forget to rate the solution if it was helpful or resolve your issue
Jul 26, 2008 | Dell Inspiron 2200 Notebook
MY DELL INSPIRION 2200
it might be due to problem with ram or your display adapter in the both the cases you have to open the case,
May 19, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
73 people viewed this question
Alun Cox
