Question about Creative Labs Zen Digital Media Player
Need ot reformat a zen. How do I do it
How do i do it
    Scholar:
    New Friend:
  • 70 Answers
George,
Connect your ZEN to a PC, once the PC detect your player a new removable device will be add to "My computer" either drive . point the newly found device and right click mouse button into it. a dialogue bix will appear indicating selecetions, choose "Format" then left click mouse button,
cheers,
mark
Posted on Feb 01, 2009
Good day i really hope you can help me out, cause I'm really feeling blue about my ZEN, cause i love it so much. I was transferring some files to my creative Zen 32GB when, it looked like the transfer was...
This can be fixed,
Most caes what we got here is a bad battery, now most people will call me nuts but once they changed there battery they found there device now fuctional. The battery is inside and I would recommend highly you send it in to have it changed out verses doing it yourself.
The unit will be reformatted and returned to your in working order the people who do this is www.pdarepair.com yes you do need to send it in unless you can find someone local.
there is no magic tricks, RESETS or anything you would might have though before comming ot fixya.com so please be advised the only fix here is changing out the battery thus the unit will loose all data.
Thanks
Jul 28, 2010 | Creative Labs Zen Micro MP3 Player
Stuck on the logo zen neeon 2
remove music and reformat then put music again
Jun 23, 2009 | Creative Labs Zen Neeon MP3 Player
Player wont open; is reformat possible?
you have to get a toothpick and then stick it where it says restart.
then it should work =]
Oct 06, 2008 | Creative Labs Zen Digital Media Player
Zen
If the computer's reformatted you (might) have to reinstall the zen. Go to "control panel" >> "add hardware" and try add it again
Jul 21, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen - can't download music from XP SP2
When you plug the Mp3 player into 2 computers running slightly different versions of XP, a reformatting occurs which will cause it not to work on one PC or the other. You must reformat your player for the home computer. Actually, you might want to check the firmware also: Go to Creative's website and double-check the firmware - it will also give you the best way to reformat your player:
http://support.creative.com/Products/Products.aspx?catid=213&catName=MP3+Players
Jul 06, 2008 | Creative Labs Zen Digital Media Player
My creative Zen 8Gb wont allow more than 597 songs..
I'll run a cleanup on your zen, if that doesn't work then you should format it and re-transfer everything. Additionally, you may want to upgrade your players firmware.
How to enter the Zen’s Recovery Mode for Clean Up, Format All, Reload Firmware, and Reboot:
1. With the Zen off, press and hold the "play/pause" button.
2. Continue to hold until you perform Steps 3 and 4. If you accidentally release the button, start the procedure again.
3. Gently push the end of a thin object (like a pin or straightened paperclip) into the Reset hole. You should be able to feel the release click of the button.
4. Slide the On/Off/Lock switch towards the power button and hold until the boot screen appears on the display.
The Recovery Mode screen appears, and four menu items are shown:
Clean Up: A cleanup of the file system and database files takes place. All (uncorrupted) data should stay in tact. When the cleanup is complete, select Reboot. Your player restarts and starts rebuilding its music library. All files should remain intact unless they were detected as being corrupt.
Format All: This will completely reset the Zen and remove all user stored files on it.
Reload Firmware: This will prepare the Zen to accept a reload, new, or older firmware based on the specific firmware file you download and execute on a computer. Selecting this option will prevent your Zen from being able to boot, so make sure you have the firmware file on you computer and ready to load.
Reboot: This will execute a soft reboot of the Zen's operating system.
How to Clean Up, Delete Temp Files, and Reformat the Zen using Zen Media Explorer:
1. Plug the Zen.
2. Go to Zen Media Explorer.
3. Select "Settings and Information".
4. Select the "Tools" Tab.
5. This page will show you the options to Clean Up, Delete Temp Files, and Reformat the Zen.
(Warning: When reformatting, you will lose all files you put on the Zen)
Jun 19, 2008 | Creative Labs Zen Digital Media Player
Creative Labs Nomand Jukebox Zen Xtra
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved.
Oct 31, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
ZEN NOT DOCKING TO COMPUTER
if you are using a fromt usb port- switch to the back usb. The front ports don't always give the zen enough power. Also- look in Device Manager and see if there is a zen listed there- and if it is does it have a yellow exclamation mark? It may not be the zen that is having problems but your computer.
Oct 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen Microphoto frozen..
Solution ID # 4794 from creative site ZEN Micro and ZEN MicroPhoto 1. Make sure that the battery is charged. 2. Detach the ZEN Micro or MicroPhoto from the PC, and ensure that it is turned off. 3. Remove the battery. 4. Move and hold the Power button to the Power On position and re-insert the battery to the ZEN Micro or MicroPhoto. Hold the Power button until the Recovery Mode appears. The following options will be displayed: -Clean Up : Scans the player and removes invalid links from its music library.Does not affect music files themselves. -Format (All):Caution! Erases all content!Save a copy of your player's content before formatting. -Reload OS/ Firmware : Caution! Erases your player's firmware. DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install. Reboot Reboots the device.
Jul 29, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Creative Labs Zen Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
