Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Is there an HDMI port on my 60V500A?
Is there and HDMI port on my 60V500A? I'd like to connect my PS3 to it. Thank you.
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
The hdmi ports not whork whit my ps3 and my computer port
HDMI sends video from a component to a TV. It most likely will not send video from a PS3 to a Computer. Try connecting your computer to your TV via HDMI, and your PS3 to your TV via HDMI.
Jul 03, 2011 | Televison & Video
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
Sony strdh500 will not recognize sony ps3
your hdmi port doesnt carry audio to all speakers what is perfectly normal for low end receiver, hdmi pass through audio only
Nov 30, 2009 | Sony STR-DH500 A/V Receiver
After installation of ps3 and blue -ray disc remote control. tried using remote to turn on and play a dvd dics to no avail nothing works the ps3 player nor the remote does't appear to recognize each other...
Ive had the same problem with mine. I have a universal remote and a blu ray player separately installed on my tv. The only way i was able to play the ps3 without calling geek squad to reconfigure my tv was to unplug the blu ray and put the ps3 in its spot and push watch bluray. It worked great.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
Cant connect hdmi to playstation3
The 3-Port HDMI System Selector is by all conventional standards a standalone HDMI system selector. It is independently powered, it comes with its own remote, and use with a PS3 is technically optional. Obviously, however, the 3-Port HDMI System Selector was aesthetically designed for the PS3, and it features some nice benefits for PS3 users. For starters, the 3-Port HDMI System Selector doubles as a cooling system with its two built-in cooling fans. Additionally, the system selector also integrates with the PS3 and the included remote can be used for controlling DVD and Blu-Ray playback.
or you can watch it on the video how to connect it
www.youtube.com/watch?v=v_6NiUIanyg
regards JAN_yuanjia rate it pls
Dec 06, 2008 | Video Game Consoles & Games
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
