Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Colors no good anymore
When I first got my ESP 3, the colors were right on. Now, even with brand new cartridges, the colors aren't even close.
I cleaned the contacts with distilled water and cotton swabs very carefully, but this didn't clear anything up at all.
Any suggestions?
Dan S
danshumar@comcast.net
  • 45 Answers
You need a new printhead. They are defective. Call Kodak, they are aware of the issue.
Posted on Feb 04, 2009
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
My kodak esp 3 won't doesn't recognize the new black ink we put in
I'm having this same problem with both black and a color cartridge. I see the small scratches, so looks like they are connecting all right. The new cartridges are Kodak brand, so that's not the problem.
I'll try calling them about the print head if that might be the problem.
Nov 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Just installed new cartridge but blue and red colour is not appearing on calibration sheet..?
Sounds like a bad color cartridge. Start by cleaning the bottom of the cartridge where the ink comes out of with a blank paper until the ink shows on the paper for all colors. If you can't get them to show all colors i would take the cartridge back and tell them it is defective.
Mar 07, 2011 | Kodak ESP 5 Printer
Bought new ink and not all the colors are printing black ink works good but colors red and yellow not showing up
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a kodak ESP-3 all in one printer that has a new black, and new color ink cartridge, and the printer does not print any colors. only prints black, grey, and a litte bit of greenish tint.
Inkjet printers do not like being left unused.
The color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a brand new kodak esp 3200 all in one printer. The ink cartridges do not last for the 400 or so sheets that is says but that is not the problem. The quality of the print is not good. I constantly...
Brand new ? take it back to the store ? ask for a replacement but pick a different brand ,maybe a small $ adjustment might be necessary depending if you pick a more or less expensive brand .
Oct 23, 2017 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black and Yellow do not print even with new ink cartridges
no,, it can be like,, you have used those colors prior usages..
Sep 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Colors won't print
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Aug 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Even with brand new cartridges, the colors aren't even close.
If you go under the printer settings there should be a maintenence file. Try to clean the heads.
Jan 31, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Uneven color in black only all other colors are good. All toner cartridges are brand new
It sounds like you have a faulty black cartridge. Even the genuine cartridges can have this problem
Dec 15, 2008 | Office Equipment & Supplies
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
50 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
