Safe mode keeps appearing on my desktop
I have to turn my computer on and off about 10 times before it will go to windows. Safe mode continually appears on the screen. No set pattern as to when safe mode will shut the computer down.
A computer engineer has replaced the battery and power pack. I have also changed the monitor. I've checked the control panel settings and this is set on permanent.Can anyone advise me?
  • marieaf1960 Jan 31, 2009
    Thank you for your comment, i will check it out.
  • 31 Answers
This may sound stupid but your F8 key may be stuck. Has anything been spilled on your keyboard?
Posted on Jan 31, 2009
Disable safe mode
Which operating system and do you have Norton antivirus ???
Turn Off Safe Mode
You rebooted your PC at least 10 times now, and still it refuses to start in anything other than Safe Mode.
Your many attempts to perform a system restore have yet to be victorious. It just will not boot up normally.
According to Microsoft, if you have Norton Antivirus 2001 installed on your computer, it is the root of the problem. Microsoft suggests you disable it.
Restart your computer. Let it load completely in Safe Mode.
Press "Run" on your Start menu.
Once you see the Open box, enter into the provided text box: misconfig.
Then press "Enter" or Select "OK."
Select on the new dialog box that has appeared "Selective Startup."
Select "NAVAP.VxD" on the Static VxD tab.
Remove the check in the check box you now see.
Select "OK."
Remove the check in the check box next to Norton Auto Protect.
Select "OK."
Reboot your system and it will be in Normal Mode.
Turn Off Safe Mode in Windows XP
The purpose of booting your computer in safe mode is to resolve issues.
Only your basic, most dire drivers and programs will run to block viruses and surreptitious software from executing on your system.
But once the issue is resolved, you need to get back to the standard Windows mode. In order to turn off safe mode in Windows XP, you must go through the same steps that you took to turn it on.
Reboot your Windows system.
Press the "F8" key several times as soon as you see the first Windows XP logo appear on your screen as the computer is booting.
This will bring up a black screen that displays the "Windows Advanced Options Menu."
Press the down arrow button on your keyboard to scroll down the list.
Select "Start Windows Normally" and then hit "Enter."
Allow the system to boot.
Enter your Windows XP user password (if you set one) and log in as usual.
Nov 14, 2013 | Computers & Internet
On my window update i get error code 663
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
The 633 error is a connection problem that appears every time you try to use the modem on your computer.
It states "modem is already in use" and prevents you from accessing the Internet.
This problem mostly appears when a device with incompatible drivers has conflicts with the modem driver on your computer system.
The major software that causes this error is the Palm Pilot Software.
With some simple troubleshooting steps, resolve this modem communication error.
Shut down all currently running applications and restart your computer.
Press "F8" repeatedly before Windows begins to open the Windows Advanced Options Menu.
Scroll down and select "Safe Mode." Press "Enter" to log into Windows Safe Mode.
Safe Mode is used for troubleshooting and repairing system components.
Click the Windows "Start" button and select the "Control Panel."
Double-click "Add or Remove Programs" to open the programs window.
Click "Program and Features" (Windows Vista users) and select "Uninstall a Program" to open the programs window.
Click the incompatible software (e.g., Palm Desktop and Synchronization Software) and select "Change/Remove."
Click "Yes" to confirm and uninstall the program from your computer.
Restart your computer normally to complete the process.
Hope this helps
Nov 13, 2012 | HP Pavilion A6400f Desktop PC, Refurbished
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
I am reinstalling windows 7 from the recovery disks. the install seems to have completed but the screen seems to hang on the final stage where it says DO NOT turn your PC off. this has been the case for...
Turn it off. If it doesn't by pressing one single time, keep pressing for few seconds, until it shuts off. Wait 10 to 12 seconds. Turn On and press F8 mutiple times so you go on the menu for safe mode. Remove the CD, then, select Safe Mode. Once in the safe mode, reboot your computer. That way, programs that were not closed properly will be closed.
Sep 24, 2011 | HEWLETT-PACKARD Pavilion Slimline s5212y...
Hi, I have an Acer Aspire Z5600 with Windows 7. Every day when the computer is turned off, during the windows updates the screens turns gray, red and green intermittently even if I reboot. I have to...
Safe mood allowed for the computer to recapture a default manufacturers version during when malfunct was encounted. Once the computer has been made to resort to safe mode also requires to manually adjust to user functionality mode else would continue to pwoer off and power on displaying safe mode.
Feb 17, 2011 | Acer Aspire Z5600 PC Desktop
How run in safe mode with windows vista
When you turn on your computer, press F8 and that will give you some start up options, the first ones being Safe Mode, Safe Mode with Command Prompt and Safe Mode with Network.
Nov 01, 2010 | Computers & Internet
Safe mode
Get windows 7, or downgrade to xp. lol kidding. During the start up, i beleve its either f11 or f12 press them it should bring you to a boot screen. follow option. or you can use the compaqs built in recovery system. reinstall your system. vista has a option to save its old files for transfer.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
I just installed xp pro and it keeps freezing
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
Desktop is blank
Shut your off. Wait 30 seconds. Boot the computer up into safe mode by pressing f8 before the Windows screen appears. Select Safe Mode and press enter. Once the desktop appears, restart your computer the normal way.
If it continues you should reinstall your operating system to fix the problem.
Aug 02, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
