Question about Apple iPod nano
Nano Ipod stuck in disk mode:
I have an 8 gig Ipod Nano. I connected Ipod to my computer to charge battery,when I came back hours later to play Ipod there was a screen displayed I had never seen before.Top of screen reads disk mode, bottom of screen reads do not disconnect, w/ a circle w/ slash,blinking. I tried pressing menu and other functions w/ no results.  please advise.
  • 342 Answers
Simply reset the iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Posted on May 27, 2009
Froozen and wont do ANYTHING
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    • utting iPods with a Click Wheel into disk mode
      1. Before placing the iPod into disk mode, you should verify that it is charged.
      2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
      3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
      4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
      5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
      If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
      If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Jun 05, 2010 | Apple iPod nano
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
My ipod nano is stuck on language selection and is frozen can you help me?
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
    Hope i helped you.
Thanks.
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Charging and lock button stuck
i have lost my code for my ipod nano a1199
Aug 06, 2009 | Apple iPod nano
My ipod 3rd generation has a white screen and it beeps twice
tray this first. Rest the nano
  1. Turn the Hold switch on, then back to off.
  2. Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
  3. You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following the next step. How exactly you check a charge on an iPod screen that is completely white has yet to be revealed. But hey, give it a shot anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
  2. Press and hold the Menu and Select buttons until the Apple logo appears
  3. Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
May 24, 2009 | Apple iPod nano
My i-pod nano chromatic 8 GB is stuck!:S
Press and hold the Menu and Centre buttons at the same time until the apple logo appears. (This usually takes between 5 and 10 seconds.)
Information from: http://ipodsurgery.com/reset-frozen-ipod
Feb 01, 2009 | Apple iPod nano MP3 Player
Ipod Nano 4th Gen 8 gig will not charge on my computer VIA USB or even connect if it is charged by another computer. used my cable on my computer and other computers and it worked fine, I can charge and...
So what you can do is connect the ipod to computer (Connect it to USB Port at the rear of you desktop computer and charge it). then try these steps:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Jan 05, 2009 | Apple iPod nano
16 gig fm ipod nano
There is no 16 gig ipod nano
May 27, 2008 | Apple iPod nano 3rd Generation
8 GB Ipod Nano went dead and now won't charge
does it work on the charger? if not, then contact apple or your dealer for more assistance or repairs.
If it works on the charger, plays music and so on, your battery is probably dead and you need a new one.
Mar 24, 2008 | Apple iPod nano
Ipod white screen
Reset the iPod:
Apr 13, 2007 | Apple iPod nano
Apple iPod nano Logo
79 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
