Question about Kohler K-10416-BN Fort½ Single Control Kitchen Faucet with Side Spray...
Unable to pull spout to replace O'Ring in Kohler Faucet F10416
I am trying to replace the o'rings and spout bearings to fix a leak (from just under the bonnet above the spout). Kohler instructions ask me to pull the spout to remove it from the body and expose the o'rings. However, regardless of how hard I try, the spout refuses to pull out. What can I do to solve the problem?
Going by the diagram shown on this Kohler website,
[www.kohlerserviceparts.kohler.com]
I have removed everything shown above the spout. Also, I am following Kohler's service kit instructions reproduced below:
1. Turn off water supply
2. Remove handle from faucet
3. Turn bonnet counterclockwise to remove from valve
4. Hold the base of the spout and pull up to remove spout from body
** THIS IS WHERE I AM STUCK **
5. Note the location of the bearings and O-rings on the body
6. Remove and discard existing bearings and O-rings
7. Using silicone lubricant provided, lubricate the new bearings and O-rings
8. Place the new bearing(s) and O-rings on the body in the same location as previously installed.
9. Reassemble the spout onto the body
10. Reinstall the bonnet
11. Align underside of handle with valve stem, then gently slide the handle into the valve system.
12. Secure the handle to the faucet
13. Turn on water supply. Check for proper operation.
I hope I am not missing something obvious.
Thanks for your help!
RJ
  • Anonymous Mar 29, 2014
    How do I remove the hande on Kohler sink faucet K-12175?
  • 34 Answers
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Posted on Feb 05, 2009
Need to replace O Ring but cant pull the spout off
there might be a allan screw holding it down usually located at the back of the faucet if not there is a chance that there is a screw on escutcheon just above the base of the spout this should screw off with a strap wrench.
Aug 24, 2012 | Moen Monticello Single-Handle Kitchen...
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
I have a Kohler kitchen faucet, model# K10416CP that is leaking around the bottom of the center ring just above the spout. It leaks very bad when we change the position of the spout. Can we fix this...
yes, remove the nut and lift the faucet up and out, you will see a rubber washer/o-ring that is like chewed up, at any home improvement center,hardware store or even a discount in there plumbing section they have faucet repair kits. Either take the old piece or the faucet and match it up, then reinstall and it will all be good. Good Luck Tim
May 22, 2011 | Kohler Plumbing
If I move the faucet from one side of the sink to the other water starts to leak out of the top near the handle. How do I fix this?
Remove the spout and replace the o-rings and don't forget to lube the o-ring before assembling the faucet.
You should use a lube designed for the application commonly know as plumber lube.
Feb 11, 2011 | Kohler K-12185-CB Fairfax Single Control...
I have a Kohler Fairfax 12176 kitchen faucet and it is about 4 years old. It is starting to leak water out of the spout for a split second on occasion when you turn the water on. As time goes on, it is...
Kohler K-79402-CP aerator kit
Kohler K-78250
Kohler 1001100
You might try to replace aerator on end of spout if water is leaking around it, or you might try to replace cartridge. VALVE (CORALAIS AND FAIRFAX)
K-GP77548
$14.80 List Price
Call Kohler if you need more info.
Dec 16, 2017 | Kohler K-12176-PB Fairfax Single Handle...
Water is leaking at the base of the faucet not dripping from the spout
You probably have a torn O - ring on the base. You'll need to remove the handle assembly and unscrew the top section to gain access to that O - ring. Remove O - ring in as few pieces as possible and take it to your local hardware store with the piece the O- ring goes on to get a replacement. Lightly grease the O-ring with vegetable oil before installing to aid in swiveling the spout. It is necessary to take at least 1 piece of the O- ring for matching up the diameter. Auto parts stores also have O-ring selections but may not have the correct diameter and thickness. You must have the exact size and thickness - anything else will not work, and close to it won't work either.
Dec 03, 2010 | Kohler Model 10433: Fort® Single-control...
I have replaced the cartridge on my single faucet single handle moen kitchen tap, but water still leaks out under the central area that holds the cartridge. Is there a schematic that shows where and what...
did you replace the spout, -o- ring's. they would cause a leak to show up there as well.no need to pull cartridge again,just handle,and then pull up spout and that is it. there should be a small packet of lube w/ -o- ring kit,lube up around shaft and new -o- ring's.available at any good hrd ware store
Apr 19, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Moen single lever kitchen faucet leaking at base and through spray. Can it be fixed? I lost my installation manual. Are there any online?
base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
May 09, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
Kohler K-10416-BN  Fort½ Single Control Kitchen Faucet with Side Spray... Logo
2,516 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
