Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman 1/2 HP Starts AND Stops Going Up or Down
My Craftsman 1/2 HP (about 7 years old ) is giving me a fit. Sometimes it will open & close fine but about 80% of the time it will start to go up then stop. It will do the same thing going down. You have to keep pressing the button to finally get it to open or close. Does this with wall button, remotes, and outside key pad. I have a drop light plugged into the other outlet where the unit is plugged into and the drop light stays on so i am not loosing power. LED lights on the safety beams seem fine. Could the safety beam be damaged, is there a way to by-pass them it see if that is it ?
Any ideas ??
  • 1 more comment
  • Ralph Esposito Feb 01, 2009
    Ok, I adjusted the Force screws to the MAX (yes I have the manual) I don't think that it will help as I had adjusted them half way before and it still did the same, I will see how the Max setting works. If it still does the same problem jump the safety beams correct ? Which one is the receiver ? and do I just twist the two wires together that go to the receiver beam only?
    THANKS
    OK jump the terminals on the power head where the safety beams hook up, will give it a try, Adjusting the force screws did not help.
    Thanks
  • Ralph Esposito Feb 02, 2009
    I found a poor connection at the power head where the receiver sensor wire connects , I doubled up the wire and it seems to work fine now.
    Thanks for the help.
  • 360 Answers
With the age of the door, chances are it just doesn't move as easily as it once did causing the built in limiters to stop the door. the limiters are designed to stop the door from crushing something or someone if the safety beams fail and there is an obstruction in the path of the door. Some units allow you to raise (increase) the force used to move the door. Most times the adjustment screws are hidden either behind the light lens or behind a removable panel. The limiter screws are NOT the screws used to adjust the travel of the door. If you don't have the manual for the opener, you may be able to download one to assist in locating the correct screws if the opener has this adjustment. As far as by-passing the safety beams, just place a jumper wire in place of the safety beam receiver.
Please take the time to rate this solution.
Thanks for using Fix Ya.
Posted on Feb 01, 2009
  • clarkco2002 Feb 01, 2009
    The manual and/or the unit should indicate which screws are transmitter, and which screws are receiver if separate sets are used, if only two screws are used for the safety beams, simply place a jumper between them.
I have a 6 year old craftsman 1/2 HP model139.53985D garage door opener. Sometimes it open/closes fine - other times it opens or closes 6 inches at a time and stops. Springs are fine, worm gear is fine -...
Generally when the door is closing any problem will cause the door to reverse to the open position and stop. This is designed into it. You say your opener just stops when going up or down. This makes me think there is a bad connection somewhere and you are simply losing power. If this is so you should notice that all the small lights that are normally on go out. If this only occurs when the door is going up you may have a bad RPM sensor board. This is a small printed circuit board just in front of the motor.
Aug 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have two craftsman door openers. They work great with pushbutton on wall, open and close ok. The door opens fine with remotes ( one handheld other homelink in car ) but will not close with remote. It...
If the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the lights on the sensors are both on and not flickering. Tweak them if necessary. If you cannot get both lights to come on you have bad sensors or the wiring to them.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 hp garage door opener will go up fine with the push of any button but it starts then stops when I try to push the button for it to go down. It acts like there is something in front of the...
If the main light flashes 10 times when the door stops it is a door sensor problem. Make sure the small light on each one is lit and not flickering. If the main light doesn't flash you have either a bad IR sensor which is a small printed circuit board just in front of the motor or you need to increase the down force which is a control on the rear of the motor unit.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have an old craftsman 1/2 hp door opener. It
You may have a bad wall control. Try disconnecting it from the opener and try. Otherwise it is time for a new model.
Apr 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Older model 1/3 hp craftsman goes up not down with remote
Your door sensors are either bad or need simply to be aligned. They must be pointed at one another to work properly. Each of them has a small light that will be lit when they are pointed correctly.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door openly opens 5-6 in, then stops.
If the door isn't unusually heavy when you open it manually then maybe an adjustment will help. On the back of the motor unit you will find the 'up force' control. Increase it 1/4 turn and try.
Jun 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberline 1/2 hp belt drive opener that stops opening
It sure sounds like a broken spring. Sometimes the break can be difficult to see. How heavy is the door to lift manually. This will give you a good idea.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2HP VERY Erratic Works then won't
Strip a little more of the wire out on the end, double it over and gently twist, making the apparent bare end of the wire 'bigger'. Then, stuff it back in the push connector.
This will make the diameter of the wire a little larger, and also a little "bumpy", giving the friction connector a little more something to hang onto.
Mar 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door wont close all the way
NOT SURE WHAT UNIT YOU HAVE .
ALL OPENERS HAVE AN ADJUSTMENT TO TELL IT HOW FAR TO GO UP AND HOW FAR TO GO DOWN. LOOK ON THE SIDE OR UNDER A LIGHT COVER.IT HAS TO BE THERE SOMEWHERE
Nov 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door hard to close have starts to close stops and starts to open again have to keep stopping and reversing door mult times to get closed
There should be two small white adjustment knobs on the side of the unit that you turn with a small flathead screwdriver. These are the load / limit adjusters.
What it happening is it think there is something stuck under the door (like a car hood, etc)
These adjustments are VERY sensitive, so be patient while adjusting them.
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
176 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
