Question about Lite On LH-20A1H DVD RW Dual Layer Burner
Lite On LH-20A1H DVD RW burner refuses to recognize DL disks?
So I'm trying to burn a Double Layer DVD using my Lite On DVD drive, which has so far been perfectly capable of doing everything else I've asked it to do. Except now I've discovered that it refuses to recognize double layer disks. Now, I was under the impression this drive was fully capable of burning double-layer disks. Am I wrong, or is my DVD drive broken?
  • 3 more comments
  • Anonymous Feb 05, 2009
    Ditto here. It won't even recognize Verbatim 8x DVD+R DL. I did a firmware upgrade that didn't fix it.
  • Anonymous Feb 17, 2009
    Me too.. it just wont read the damn disc.. keep sounding.. T_T
  • Choujij Mar 24, 2009
    There is something wrong with this new DL media from Verbatim, it's happening to a lot of Lite-On users including myself. Check out CDfreaks.com as they try to figure this out.
  • Anonymous Apr 20, 2009
    im having the same problem with dual layer discs,, my lite on LH20A1L will not pick up the **** and im using fugi film dvd r DL, fuckin *** though
  • Anonymous Apr 22, 2009
    having the same problem with the same exact drive here burned about 50-60 plus dual layer dvds now won't recognize Memorex DVD+R DL
I have an LH-20A1S, & I am using Roxio Easy CD
Creator 6; Yes, I know there are newer versions, but they all ****! Anyway, it USED to work just fine in recognizing DL DVD's W/the updates from Roxio's site. & now there is no option there for this size (8.5)w/in the actual Creator prog. Is it the drive? This JUST started happening recently. Any clue if it IS the drive? & if so, any idea what caused this? I've always used Lite-On's & have NEVER had this sort of prob before! & of course it is out of warranty, & a discontinued model to boot! standar DVD drives are real cheap inprice these days, but STILL I do't wanna have to buy an new one if I can 'fix' it. BTW, I have updated the latest firmware for this drive from Lite-On's site too, & it didn't resolve this issue either!
__ERIC
Posted on Nov 22, 2009
I put in a dvd/rw disc and it will not read it. in My Computer it comes up as a blank disc (cd)
Make sure the discs you are using are compatible with your drive. Some drives will burn dvd - r discs but not dvd + r discs. Hope this helps.
Jun 09, 2011 | Lite On LH-20A1H DVD RW Dual Layer Burner
DVD recorded refuses to read dbl layer dvd it just burned
try burning the dvd's at a lower speed, most of the dbl layer drives have similar type of problems.
Jul 15, 2010 | Lite On LH-20A1H DVD RW Dual Layer Burner
STOPED WORKING ONLY GET CODE 39 WAS HAVING BURN PROBLEMS ESP WITH DL. Uninstalled roxio 2009 but after lost burner icon in My Computer.Ran various dianostics get saying need pro attention???
hi..shut down you computer and try to change the IDE/Sata cable that connect you dvd to your computer, and turn computer back. in control panel double click on "add new hardware" and follow the wizard
Oct 29, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Unable to erase DVD-RW
mebbe you need the latest drivers..methinks..
go to your computer maker, and get the dvd drivers
you may find your computer listed here
Mar 23, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
My LITE-ON DVDRW LH-20A1H thinks its a cd burner???
It seems Lite-on Has a lot of Probs.In fact I had the same model on an SATA system.It would not burn dvd's or cd's.You can try updating your burning software,and reinstalling the drive through device manager.I actually ended up buying an LG burner....lo-and behold...it works without any problems.Good luck
Feb 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Won't reognize about half of my DVD Rs
The only thing that it might work if you use DVD-R some writers and home theather seem to not like DVD+R
Jan 08, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
'Problem Copying' when burning files to DVD-R
YOU NEED TO BURN THE FILES
TRY UDF FILE FORMAT IN THE SETTINGS I'f suggest nero burning rom
Dec 21, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
PROBLEMS WITH MY DVV BURNED
YEAH there is something stuck in the drive open it and clean it out
or the disk is defective
of your drive is going
OPEN YOUR DRIVE UP FIRST
Dec 16, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Will not reconize Memorex blank dvd-r'sometimes
YEAH ITS THE DRIVE NOT THE DISC
LITE ON AND PIONEER CARRY LIMITED FIRMWARE ( support for media)
I USE RIDATA on SONY AND PIONEER BURNERS
Oct 18, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Lite On LH-20A1H DVD RW Dual Layer Burner Logo
934 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
