Question about RTO Mobil Line Mobility Scooter Chair Battery Charger31004
No output from circuit board
Replaced TR5(SCR), but it didn't come for 6 weeks. Now I don't remember how the white and the black output wires hook to the
printed circuit board.
Also, does the output need a load(the batteries), in order to show a
voltage of 24V? . (It depends on the output circuit).
If I had a schematic of the PC board, I could troubleshoot it better.
Thanks for your help,
Doc
Doc,
I'm working on one of these chargers tonight. The white wire from the internal breaker is connected to terminal "PL" and the black wire to terminal "MS".
Hope this helps... Maybe you can fix my circuit board! Several fried components.
Jason
Posted on Nov 05, 2009
Motherboard connections (to front panel)
remember the colored wire is +, the + and - should be printed very small on the board near the connectors as well as what they are example (HDLED is hard drive LED) or (PWRLED is power LED) or (PWRSW is power switch) these are examples yours may differ slightly
Jan 31, 2013 | Gateway (4000811) Motherboard
The plug got torn off the the back and i do not no what or were to hook up the break lights nor do i no how to add a plug for a trailer can you please help me out
  • Hi, not sure which one you have so I will list both for you.
  1. Ground - Black
  2. Blk/Orange - Park lamp relay output
  3. Yellow/Pink - Trailer tow right relay output.
  4. White/Pink Trailer tow right turn relay output.
  1. Nothing.
  2. White/Pink - Trailer tow right turn relay output.
  3. Violet/ Black - Back up lamp feed.
  4. White/Red - Fused (B+)
  5. Black/Orange - Park lamp relay output.
  6. Nothing.
  7. Black - Trailer tow brake (B+)
  8. Black - Ground.
  9. Black - Ground.
  10. Yellow/Pink Trailer tow left turn relay output.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 12, 2011 | 1999 Dodge Ram
We have a DEH-6 pioneer radio that we are trying to install in the 1994 dodge caravan.We cannot find where to hook the white wire from the radio. when you turn the ignition on the radio lights up but the...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps.
May 29, 2011 | Pioneer DEH-P690UB CD Player
We have a Parmak electric fencer, model # s.e.3 and serial # 4401002. It just quit working. When you plug it in it makes this humming sound and then quits. Any ideas?
That sounds like the circuit board has failed in the unit. you can call Parmak and see about either purchasing a replacement circuit board , or getting the unit serviced by them or an authorized service center.
Apr 21, 2011 | Parmak Solar Fence Charger
I have a F6C800 and replaced the bateries. It seems to provide surge protection power through the 2 outlets but does not provide power through the Backup outlets. The monitoring software also does not...
OK - I'll ask the simple question first, so don't think I'm being crappy...
When you hooked the wires back up to the batteries that were replaced, did you hook them back up as they originally were? (I ran into this problem myself earlier today. I put one of the batteries in upside down and didn't have them hooked up correctly.)
Red terminal on the front battery goes to the black terminal on the back battery, then the black terminal on the first battery goes to the circuit board. Red terminal on the back battery goes to the power supply.
Hope that helps. It sure is a pain the change these batteries out.
Nov 29, 2010 | Belkin (F6C800-UNV-PL) UPS System
I have installed Generalaire 1137 humidifier to an Goodman Furnace. Furnace Circuit board has 115V Hum terminal for black wire. should I connect the white wire to EAC terminal on circuit board as well.
The white wire needs to go to an "N" terminal. There are usually a number of white wires all in one spot and a bunch of "N" ternimals. Hook the white wire to any of the empty ones.
Heatman101
Jan 29, 2010 | Goodman Furnace Draft Inducer Blower ...
Need to replace transistor. No pin out available for red, black and blue wires, please let me know which one goes to transistor's K, A and G.
If the devce you are referring to has K (Cathode) A (Anode) G (Gate) then you are referring to a SCR and not a transistor!
SCR are typically used in AC light dimmer and motor speed control.
You should always use the same or higher rated equivalent component: a Transistor (usually used in DC circuits) IS NOT a substitute for a SCR (usuallly used for AC circuits)!
PLEASE REMEMBER THAT YOU ARE DEALING WITH LETHAL AC MAIN VOLTAGE so unless you are familiar with both Electronics and Main powered devices, I would NOT recommend that you attempt this repair.
As a general rule, if you cannot identify what the original device was and where it originally came from on the circuit board, I would leave it to a qualified person.
Hope it helps you make the right decision.
Jan 14, 2010 | Bosch 1 - 1/8" Reciprocating Saw RS5
How do you wire a Two Single Pole Switch for each switch to run seperate lights all off of one circuit. Example: Recess Lights on one switch and a Track light on the other switch. 6 black wires, 6 white...
so 6 grounds is connected together, and conneted to mains ground (direct connection), the white wires is (mains Neutral) and you connect all 6 white wires together (to doble pole safety switch) in one end pole switch, and you connect a wire from another pole the same end at common Two Single Pole Switch and connect (Black wires recess lights) to one free pole switch and (Black wires track lights) to another free pole.
The mains connect to safety switch live (Black or Brown) to another free safety switch pole, Neutral (White or blue) to free safety switch pole and earth to ground wires on mains connector.
Note: Allways use a mains 300mA diferencial safety switch, for better protection.
Jan 02, 2010 | Computers & Internet
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Kitchenaid Mixer K45SS
I just did this last week!
1 Unplug Mixer 2 Remove screw on TOP of mixer body, at back. 3 Remove rear cover and paper-gasket thing (its not the end of  the world if you end up tearing it a little). 4 the phase control (little circuit board w/wires) is at the top (you  should see it very easily) held on by one screw, remove it. 5 when the circuit board is unscrewed, disconnect all the wires  that are connected FROM THE CIRCUIT BOARD to the  black control plate (NOT all wires-there should be 4 left on  the control plate at this point).  you don't need to  remember where all the colors go as the control plate is  labeled->but looking at them and making sure you  understand the abbreviations would be beneficial  (BK=black, BL=Blue RW=Red&White W=white R=red etc.   6 install new phase control (screw), either buy new thermal  grease (used to keep the board cool->it transfers heat to  the mixer's housing) or try to salvage what you can from  the old one. 7 connect wires, paying attention to labels. 8 reinstall paper gasket, then cover, then screw to hold on back- cover.
Jan 17, 2008 | KitchenAid K45SS Classic Stand Mixer
RTO Mobil Line Mobility Scooter Chair Battery Charger31004 Logo
266 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
