Question about JVC HD-52G886 52" Rear Projection HDTV
Picture problem on jvc hd ila 52" hd52z575
On the bottom middle of the screen a 12"x10" darkened area. Not sure if its a "burn in" from playing Wii video games, or another issue.
  • carenyllie Feb 27, 2009
    There's a long black streak across the bottom of the screen. It's as if it's IN the screen. Sometimes some of it fades and then comes back. The thing is after we had the TV for a year, the same thing happened and it was under warranty so they replaced the whole screen (said it's normally about $700). That was a year ago, so another year goes by and we now have the same problem again. It's no longer under warranty so I'm freaked this will happen year after year if I can't find a cheap way to fix it.
  • ampscomm Mar 03, 2009
    JVC 56GC87 HDILA - black spot that runs from the bottom right middle to the top ....it's a dark area that looks like it's in the screen. The bulb was replaced and a repairman said it could be the light engine...and if it is it takes him 2-3 hours to try to bring pixel back ...that could cost $450..if a new engine is needed it's about $1000. The doggone thing cost a little over a grand.
BMW Rider
  • 232 Answers
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
Posted on Dec 12, 2007
ctf1800
  • 4402 Answers
SOURCE: jvc 52 inch hd-ila hdtv widescreen
you have a bad lamp or balast
Posted on Jan 22, 2008
  • 1039 Answers
SOURCE: HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Posted on Apr 25, 2009
SOURCE: I have a 56" JVC rear projections HD ILA tv.
Turn tv off and unplug it. Take the access door off either side of the tv. Use a dust cleaning tool like a swiffer with an extension (or make one). Clean off lens (most likely the problem). I have the same thing that happens to my JVC 61". You can use a vacuum with extension if your VERY careful.
Posted on Aug 31, 2009
  • 12 Answers
SOURCE: JVc hd ila both led blinkin fast. Blck screen.
your lamp is burned out, buy a new one online and replace according to the instuctions sent with new lamp. this a cheap and easy fix-dont believe anyone that tells you different-they are usually people that work in the tv repair industry and want everyone to think they belong at NASA!!!
Posted on Feb 08, 2010
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
I am trying to change out a bulb in a HD-ILA
I have a tip which explains the procedure at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv Let me know if you need any more help.
hardrocko
Thanks for using FixYa
Feb 20, 2010 | JVC HD-52G787 52" Projection Television
JVc hd ila both led blinkin fast. Blck screen. There was no mesage . how to trouble shoot
Dec 04, 2009 | JVC HD-52Z575 52" Rear Projection...
Apr 25, 2009 | JVC HD-56G787 Television
Jvc hd52z575. Just replaced bulb and can't get the audio to work through Tv Help please!
first check to make sure the red and white cables are plugged in, then go into the menue , under audio hilight the tv speakers, make sure they are on, if they are, make sure the mute button wasnt turned on
Jan 08, 2009 | JVC HD-52G886 52" Rear Projection HDTV
JVC 56
thrse television are ila? which i a projection lamp type tv. burn in is internal to optics and will rigure replacment of light engine
Jan 29, 2008 | JVC HD-56G886 56" Rear Projection HDTV
JVC HD-52G886 52" Rear Projection HDTV Logo
410 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
