Question about Oakley GMT OAK0531 Wrist Watch
Date setting I got an Athletic Works pink wrist watch and do not have the instructions on how to set the date. the model number is AW209 138 PC21AF
SOURCE: I Have An Athletic Works
http://answers.yahoo.com/question/index?qid=20060901103927AANkcYr this link will explain it
Posted on Oct 17, 2008
  • 3 Answers
SOURCE: athletic works watch
I just bought an Athletic Works watch at WalMart that is identical to the Aquatech watch I bought there some years ago. My band got hard and cracked so I needed to buy a new one as the band is not available. For $9 the entire watch is probably cheaper than a band. I used the instructions from my Aquatech to set the stuff on the AW. I found the instructions on the internet. Here is one site that has them.
http://www.ehow.com/how_4587869_set-aquatech-watch.html
Give it a try.
Clem S
Posted on Mar 04, 2009
SOURCE: CAN'T SET TIME
I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
Posted on Mar 09, 2009
SOURCE: athletic works watch owners manual
if you press both buttons on the right at the same time it might work. Im not sure if it will for ur model, but it worked for mine =)
Posted on Aug 17, 2009
rokkitsci
SOURCE: athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Posted on Jan 05, 2010
Do not know how to set date and day
Hi, Since Citizen does not list this caliber number on their site, try another caliber number close to your model, with the same features. I've been successful with this procedure more often than not. Most setting instructions are near the front of the manual, between pages 3-9. If you don't have the manual, Try this link:
http://www.citizenwatches.com.au/instruction-manuals
Take the four-digit Calibre number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 02, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support webguy@fossil.com
hope this helps
Mar 25, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
Date setting.
Go to the "www.citizenwatch.com" site, select you area.
l
Select "technical support"
Then "setting instruction"
Enter your model number.
Dec 30, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
How to set the time on Athletic Works watch
Press and hold the lap/reset button for at least 5 full seconds. You should see the word "SET" appear in the dispaly. Push the Mode button to change from alarm to date to month, time, etc.. Use the start/stop button to change the numbers.
Jul 13, 2009 | Watches
Athletic wrist watch stuck in 24 hour mode
Apr 30, 2009 | Watches
Need manual/User Guide for an ''Athletic Works'' watch, model V403
Dave,
If you hold the reset button you will see the number 12 flashing with an H next to it this is for standard or military time. To change it press the st/stp button. To go forward press mode.Then it will ask for the year set that then press mode.Now the date change it just like the Hour and year.then day do the same.Now timeSet that the same and it should work!
Apr 26, 2009 | Watches
Athletic Works Watch
With time displayed:
Press lower right, then upper left.
Mar 12, 2009 | Oakley GMT OAK0531 Wrist Watch
CAN'T SET TIME
Feb 28, 2009 | Oakley GMT OAK0531 Wrist Watch
Athletic works watch
Give it a try.
Clem S
Sep 23, 2008 | Watches
Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Oakley GMT OAK0531 Wrist Watch Logo
268 people viewed this question
Top Oakley Watches Experts
Andrew Taylor
Andrew Taylor
The Scrivener
Are you an Oakley Watch Expert? Answer questions, earn points and help others
