Question about LG LRSC26980 Refrigerator
LG REfrigerator - water line connector
Water Line Connector in back of refrigerator started spraying water everywhere (leaking) at the connector (caused $5,000) damage to wood floors, etc. LG repairman came out, and replaced connector (water leaked again) about a month later but noticed in time to shut off water. All connectors / tubing are plastic !!! Is there any way this can be converted to copper tubing / connectors to alleviate this problem, or do I need to purchase another refrigerator (from another maker). Unit is only 3 years old and was very expensive. Thanks.
  • 3 more comments
  • Anonymous Jan 24, 2008
    I had the same problem with copper tubing.
    I tried to fix it with plumbers tape, no luck.
    I just shut off the water source and I buy Ice at 7-11.
  • rgrose23 Jul 01, 2008
    replaced leaking water connector and the new one still has a small leak. Did I connect it properly? Is there a trick?
  • Anonymous Jul 22, 2008
    The plastic line on my refriderator is developing pin hole size leaks which still causes major damage. This seems to be like the polybutleine pipe from the 90's
  • Anonymous Oct 09, 2008
    I had this happen on an LG fridge too and cause a fair bit of damage.. not too impressed.
  • Joyce Snyder May 29, 2013
    This happened last May and now again but worse water all over and buckling wood floor!! guess we need to disconnect water, what a shame to pay such a price for something that doesn't work!!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
Posted on Jun 03, 2008
  • builderevey Sep 03, 2011
    OMG, LG same problem leaks in the plastic water lines, 5 times... I have used coupling to
    remove tubing that has sprung leaks.. but has ruined my wood flooring, I have never had this
    happen with any other refrig....... what the heck.... looking for couplings to keep cutting out
    leaks in original tubing
Exact same problem here! We replaed the bottom tube from the fridge to the water source with copper, but you can't replace the tubing on on the fridge to the ice maker/auto water without taking the whole thing apart. It is so frustrating. I called LG and of course they said "it is out of warrantee" and we had to call a plumber for their faulty decision to use plastic tubing.
Posted on Aug 14, 2012
My new LG fridge (10/15/11) says to use copper tubing
Posted on Oct 15, 2011
I have the same problem with my LG. This is coming from behind the water filer connection hose.
Posted on Feb 18, 2010
Just got my LG. Same problem with connector!!!
Posted on Sep 11, 2008
  • francemama Aug 09, 2010
    SAME problem here!! We have an upper armoire style LG fridge with lower drawer freezer. We left on vacation and came back to a flood. Remember to turn off water line when you leave for any amount of time!! Our neighbors found the problem about 2 days after the leak started. The plastic attachment to water line just opened in two pieces. CHEAP!! Not impressed!
Kenmore Elite 795-78029. Why do I have water spraying from behind the supply line connector on the back of the refrigerator?
the valve or its supply line is leaking --damaged or loose connection if your able to isolate the problem say its the valve you can change the valve with simple tools same if water line can buy a repair kit
Aug 11, 2015 | Refrigerators
Why my refrigerator /freezer is leaking water from the bottom front near freezer and water builds up in the bottom of the freezer?
The leak is probably from the small PVC water line leading to the freezer door ice/water dispenser. Manufacturers put a small plastic joiner at that point to allow removal of the door for shipping and installation. That tiny connector can become easily disconnected and leak water onto the floor every time someone presses the water valve in the dispenser. It's easy to fix, Lowes and Home Depot have the fix-it kit for about $5, but you will probably find the existing joiner parts already attached but only needing to be rejoined.
I'll attach a photo of the Home Depot kit. you can also order it from Amazon and have it delivered right to your mailbox. Search for a "refrigerator door water line connector" and you should see a GE part number WR02X11330.
Aug 21, 2014 | Refrigerators
Icemaking is ok but I find water at the bottom of the frige .What seems to be the Problem tHIS A ULINE BAR REFIRERATOE WITH iCE MAKER
Your feed line may have a leak in the line itself or in one of the connectors. This it the line that sends water to the automatic ice-maker. Check the line coming from the wall to the ice-maker connector and slide your hand down the line. You will find water somewhere along this line and you have found your leak. This should be very easy to fix.
May 23, 2011 | U-Line Refrigerator Ice Maker
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
Feb 05, 2011 | Kenmore Refrigerators
Replacing water line in freezer side door
Yes as I stated on other posts, go to an appliance shop and get a threaded connector. Mine cost about $7 and i had to do some minor adjustment cutting to the plastic guard at the bottom of fridge/freezer...so the new piece would not put too much pressure on the line. The white coupling connector on the line u will see has a red and blue washer conected on eitrher side of water line. To disconnect line ..just push in on top of washer and pull line. Cut the torn lines so u at least have a line that is clean and mostly straight, but dont cut TOO MUCH!! just the bare edge, about 1/8 " inch. Use some needle nose pliers ,real small ones.. to pull the line from bottom of door and apply connector. Put lines back on and do faceplate and check for leaks. Good luck!!
Jul 25, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice works but no water comes out. when you press the water dispencer the waterleakes on the floor. I've been told I have a broken bladder, but I don't know where to locate it? Nor how to replace it.
Remove the toe kick, on the t side you will see a connector where two water lines meet, if the water is leaking there, push the two lines into the connector and then pull back on them to make sure they are sealed. test to see if it still leaks, if it does push the red or blue ring around the line in, while doing that pull the line out of the connector, repaet for the opposite side. use a razor or sharp knife and cut about a half inch off each line, make sure they are flat, push them back into the connector, and pull to seal, if it still leaks replace the connector. If the wateer is coming out of the freezer door replace the water line that goes through the door.
Jul 07, 2008 | Frigidaire FRS26R4A Side by Side...
Water line burnt into causing water to run on floor when water is dispensed.
Replace the line. Splicing a line can lead to leaks down the line. You can get the material you need from a local hardware store.
Jun 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
We had to take of the doors on a whirlpool sie by side refrigerator. On the side with the water line going into the door, we had to pull of the grill on the bottom and disconnect the water line. Now when...
yes easy this is called a "john guest" fitting probably after the now fabulously wealthy man who invented it. push the ring in BEFORE you remove the tube and you can use them again. availabe @ hardware and appliance supply stores everywhere
good luck!
Apr 25, 2008 | Refrigerators
Dripping water dispencer
Dripping problem is from 2 sources.  Faulty water valve or faulty water connector behind refrigerator.  If the dripping is constant and doesn't seem to end, then it's a faulty water valve.  If the dripping stops after awhile, then the water connector is allowing air into the water line causing the dripping.  Have that connection checked to make sure that it's securely in place.
Nov 12, 2007 | LG LFD22860 Stainless Steel Bottom Freezer...
Leaking icemaker
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
Oct 29, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
LG LRSC26980 Refrigerator Logo
10,115 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
