Question about Dryers
My dyer is not turning. it makes a noise like the motor is trying to turn but does not have enough to do it. my husband took it apart, belt seems to be ok, but when he took off the top he can spin the drum which gets it started for a small load
  • henrich11 Feb 01, 2009
    Motor sounds like it wants to turn, and when we manually turn it we can get it started, but it will not continue for long. The belt is fine. -We had a technician come and look at ours, they said the motor needs to be replaced. This costs as much as a new dryer! Our dryer is only six years old.
  • 29 Answers
Either the motor windings have too much electrical resistance or the start windings are shot. Replace the motor and install a new belt while your at it.
TIP OF THE DAY--To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
:?) DRRXR
Posted on Feb 08, 2009
  • DRRXR Feb 13, 2009
    You should be able to find the motor on line, but your correct in that the cost will be around 100 to 140 dollars. Good new driers run around 500 so if you opt to change the motor DIY then change the belt you could luck out and get 3 to 5 more yrs out of it. But you never know what will happen next. If you buy a new drier I recomend one with a stainless drum. If you get a stainless drum drier; then be sure to use a metal flex hose on the vent. The new SS drum unit will be more energy efficient. :?) DRRXR
Why dryer won't tumble?
The belt could be worn and stretched.
Jul 20, 2014 | Maytag MDG2706A Gas Dryer
Whirlpool dryer won't spin
Most dyers after you pull the top up, the front should just lift a little and it should come loose, sounds like you may have the belt intact, but the motor is not conected to the belt.
Jan 12, 2013 | Whirlpool Dryers
My dryer started making a high pitch squealing noise and the clothes smelled burnt. I let it cool off and it ran for a little while without the noise and today it turned itself off. My husband took it...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 07, 2011 | Crosley CDE6000 Electric Dryer
My GE electric dreyer, DHDSR46EGWW, is making squeaking noise and a grinding noise. My husband took is apart last night and put back together. When he started it the noises came back and he said it...
It could be the rear bearing or if not it have your honey take it apart again and inspect the rear rollers, if they turn freely then inspect the front bearing assy it is on the the door and if it looks worn down then it is allowing excessive pressure on the rest of the unit .
Apr 01, 2011 | General Electric DHDSR46EGWW Dryer
When dyer turned on makes a loud whriling noise and then shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sounds like the blower is full of dirt of the blower wheel came apart...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Motor or beater bar making horrible noise
The belt could be damaged. Call the Dyson helpline. They will listen to the noise and troubleshoot it for you. If it is the brushbar motor they will have a repair dealer look at it. If it is the belt that is damaged, their solution will depend on whether your machine is still under warranty or not.
Jul 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dryer drum making thumping noise
My dryer just started making this noise. So I opened the back up to try to figure out what it might be, and when I opened it I saw something. It was part of the belt that drives the dryer. There are grooves vulcanized to the belt, and a small section of grooves or cogs I think is what they are called had come apart from the belt and what laying there on the floor of the dryer. But I ran it and timed the thumps in my head to get it to stop right on the "thump". Sure enough there was a small 1/2'' appx. of belt Cog missing, so the "thump" came from when the belt came around to the motor and the pulley hit a divit in the belt, "thump". So needless to say I need to replace the belt soon before it breaks completely. I figure that it looks like someone may benefit from knowing what the noise is. Now its off to find the proper belt and look up how to change those things...Good luck to those reading this.
jiujitsujd@aol.com
Jan 16, 2009 | LG DLG3788W Gas Dryer
We have an electric Kenmore 70 series dryer that is making very loud noises - still drying well otherwise. Husband just took off front and top, and took out drum - still makes same noise when just motor is...
check yopur blower wheel and blower wheel housing...turn with hand to check motor bearing,,if motor bearing tell husband a little bit of wd 40,,or white grease at each end
Dec 28, 2008 | Kenmore 63942 Dryer
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Dryers Logo
91 people viewed this question
Top Dryers Experts
