Question about Canon PIXMA MP460 All-In-One InkJet Printer
Just replaced black ink cartridge, it sounds like its printing, but the paper is blank or barely visible
  • Canon Master
  • 5,309 Answers
Have you taken off the protective cover?
Posted on Feb 02, 2009
Black ink will not show up on paper
It seems print head clogged,this issue not related with cartridge, perform clean print heads 3-4 times & chk, if no result replace the print head (CN642A).. I won't suggest for manual cleaning for this print head unit.. Thanks for listening me..
Jun 20, 2013 | HP Photosmart Premium C309A All-In-One...
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
I have a canon ip4200. On plain paper, standard print, prints in pale, pale lavender/blue, with hyperlink in blue (clearly seen on paper); on high and custom, the print is barely visible, with hyperlink...
Ok so on reading this it appears that your are barely printing black.
1. have you tried a genuine canon cartridge?
2. have your performed cleaning on the black cartridge?
3. Start the printer and ask it to print something. While it is printing kill the power and gently move the carriage to the left. On the right side of the machine you can now see the purge unit. You will need a torch shining on the purge unit. check it to see if there is a paper scrap anywhere near or on the purge. It may be soaked in ink so may not be easly seen.If so remove it and perform cleaning again.
4. Clean the wipers on the purge with a dry cotton bud.
If none of this works then its looks like a blocked/weak printhead and you will need to replace it.
Good luck
May 22, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Just put 2 new ink cartridges in my printer - black and tricolor. the printer receives the message to print, sends the paper through and sounds like it is printing, but then the paper is blank with no ink...
Hi
Just remove the new 2 cartridges and rub the print head in a plain paper with isopropyl alcohol until ink flows, and then return the ink cartridges and run the print nozzle for 2-3 times. After that, try to print again.
Please let me know if you need more help.
Mar 05, 2011 | HP OfficeJet D135 All-In-One InkJet...
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
Printer quit printing
my black cartridge is not printing it has ink
Feb 05, 2010 | Cannon i70 Printer
Ink system failure Oxc19a0031 I have an HP842C. The ink cartridges appear to be full, and in fact I have changed them for new ones, but I barely get a print, It is sometimes enough to make out (barely)...
Clean the cartridges.
Go to Printers/Faxes from your START Menu
Select the printer
Select Set Printer Properties
Select the Services Tab
Clean them - I had to do it 5 times and take out the black cartridge and shake it really good until ink started coming out and clean it again. I primed 3 times.
Worked for me.
Sep 29, 2008 | HP DeskJet 842c InkJet Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
old marine
old marine
