Question about Novatel Art Explosion Publisher Pro for PC
Re: Art Explosion Publishing Pro. I can't move any objects or text boxes. Nothing is "locked". Why won't it let me?
Get program to restart it says it terminate wrongfully I have been using this program fr years never happened!
Try here: http://usa.novadevelopment.com/support/faq/pgw.aspx
When you say "It will not open", what happens? Do you click the icon and nothing happens? If so, find the main .exe file in the folder that contains the Nova program. double click that. Does the program open now?
However, it sounds as in the sudden shut-down corrupted some files or registry entries. If you have the CD, create a new folder in My Documents and move all your work to it. Uninstall Nova. Reinstall from the CD, move work back.
If you have no CD, you will be struggling
Sep 24, 2014 | Nova Development Art Explosion Publisher...
Is the "art explosion photo
I have this software and after changing to Windows Vista found that it was not supported
Jul 18, 2011 | Nova Development Computers & Internet
I am running Windows XP, and have been using Nova's Art Explosion Publisher Pro 2.0. However, I recently had to reinstall operating system and all software and now I cannot get my system to read the first...
hi dontwakeme
Nova Development Art Explosion Publisher Pro 2.0 only running on windows 98/2000/me and XP
what is your system operation you use now?
if vista or 7, you need higher version of Nova Development Art Explosion Publisher Pro
Mar 20, 2011 | Nova Development Art Explosion Publisher...
Create and share toolbar is grayed out
try this
The toolbars can be turned off. They can also be dragged out of the viewable area. If they are turned off, they can be turned on by going to the View menu, to the Toolbars sub-menu and selecting the toolbar that is missing. If it already has a check next to it and it is missing from the program, then it has been dragged out of the viewable area. To correct that:
Warning: Make sure that you are only deleting folder/keys that you are directed to delete in the Registry. Deleting any other folder/keys may cause problems with your system or other programs. Novadevelopment assumes no liability for changes you make in the Registry.
  1. Close the Publisher Pro program.
  2. Go to the Start button and select the Run option.
  3. On the Run window, type “regedit” without the quotes in the Open field.
  4. Click the ON button. This will open your Registry Editor program.
  5. Scroll to the top of the left-hand side of the window to where you can see the My Computer option.
  6. Click the plus sign (+) next to the HKEY_CURRENT_USER folder and this will expand a list below it. If it has a minus sign (-) next to it, skip to the next step.
  7. Click the plus sign (+) next to the Software folder and this will expand a list below it. If it has a minus sign (-) next to it, skip to the next step.
  8. On the list that appears below Software, locate the folder labeled Nova Development. Click the plus sign (+) next to the Nova Development folder. If it has a minus sign (-) next to it, skip to the next step.
  9. On the list that appears below the Nova Development folder, locate the folder labeled Art Explosion Publisher Pro. Click the label for the folder Art Explosion Publisher Pro. It should now be highlighted.
  10. On the Art Explosion Publisher Pro folder name is highlighted, go to the Edit menu and select the Delete option. On the warning box that confirms the delete, select the Yes button.
  11. Close the Registry Editor window.
Jun 06, 2010 | Nova Development Photo Explosion Deluxe...
I cant get the art explosion 750,000 to download to my Macintosh
To download or to install? Because most Mac installs usually just mean dragging an application from the image file mounted on the desktop to the Applications folder.
Mar 18, 2010 | Nova Development Art Explosion 750000...
I am in the middle of making a 30 page book on my Art Explosion Publisher Pro. Now that I am done, I can't publish it as a PDF. It gets 90% of the way there and then says.. "out of memory." Is there a way...
If are ale to print it from Art Explosion without memory problems, this might do the trick.
Download the freeware tool PDF Creator (see link)
PDF creator will create a virtual printer (PDF creator) on your computer.
Printing your 30 pages to this printer and saving the PDF instead of printing, it can do the trick.
PDF creator can also be used from every program with printing options.
Installing PDF ceator will gve you a versatile pdf creation tool.
The link:
http://sourceforge.net/projects/pdfcreator/
Sep 24, 2009 | Novatel Art Explosion Publisher Pro for PC
Loading Art Explosion 2.0 publisher pro on windows vista
I had to download an upgrade from their website to allow Vista to operate properly.
Mar 07, 2009 | Novatel Art Explosion Publisher Pro 2.0...
My new Print Explosion doesn't let me lighten objects
In reading the manual for the PE,a nd remembering how the old version worked, it appears I'm stuck-- I can lighten text but not objects. Alas. "Lightened" is a function I used all the time and I will miss it. This is the sad nature of upgrades. Technology giveth and technology taketh away. For shame, Nova Development. Who knows, I may trash the new deluxe and go back to my old system.
Jan 15, 2009 | Nova Development Print Explosion Deluxe...
Novatel Art Explosion Publisher Pro for PC Logo
Top Novatel Computers & Internet Experts
ray gallant
wensch00
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
