Question about Brother MFC 7300C InkJet Printer
Brother printer mfc 7300c machine error 33
I just pluged up my printer and keep getting error 33
jtuminaro
  • 56 Answers
SOURCE: Replace Fuser error will not go away
With in 2 seconds you have to hit Menu,*,2,8,6,4
Continue even though you hear the 3 beeps.
When it does into maint mode press 88
That is parts counter reset
Scroll to the part and hit ok.
Press 99 to exit Maint mode
Posted on Jan 15, 2009
GodBlessU
  • 3513 Answers
SOURCE: I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Posted on Jan 15, 2010
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
SOURCE: machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Posted on Apr 08, 2010
pineworks
  • 4041 Answers
SOURCE: Unable to Init - Machine error 4f
ok please try this
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Apr 25, 2010
What does error code 20 mean when printting
take the paper towel and add 20 weight oil to clean crap off the carriage then try again
Apr 21, 2015 | Brother MFC 7300C InkJet Printer
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
MAchine error 72 on the brother MFC 9700.
this code say that Cannot detect Beam Detect signal
u should call an engineer or if u wish to try ur self try
replace the toner and drum. verifie cables were pluged in correctly. clean sensors
good day
Jun 02, 2010 | Brother MFC 9700 All-In-One Laser Printer
I have a brothers mfc 9200c and it shows me error 33. What is this
Check your owners manual or users guide. It may be available for download from Brother, check the portion of the page for the country or region that the printer was purchased in.
There is some information about error 33 in the FAQ section of the site for the MFC 5100, check if it applies to your product. It seems to have something to do with the motion of the print heads.
Good Luck!
Feb 05, 2010 | Brother Office Equipment & Supplies
Will not print
 ARE YOU USING BROTHER INK??? I MEAN BROTHER OEM INK.? WHAT YOU CAN TRY IS TAKE A PAPER CLIP AND INSERT IT ABOUT 1/4 OF INCH INTO THE AIR HOLE ON THE CARTRIDGE, SOUNDS LIKE WHEN THE SEAL WAS TAKEN OFF, THE ADHESIVE FROM THE SEAL STAYED ON THE CARTRIDGE BLOCKING THE HOLDE. GOOD LUCK SR BROTHER TECH
Dec 01, 2008 | Brother MFC 7300C InkJet Printer
MFC 7300C
IT SOUNFDS LIKE THERE IS SOMETHING IN THE WAY OF THE PAPER PATH THAT IS CATCHINH THE CORNER OF THE PAPER, WHAT WE USUALLY DO IS TAKE A 8X10 FILE FOLDER AND MANUALY PUSH IT THRU THE PAPER PATHE TO SEE IF ANYTHING IS IN SIDE THEN REPLUG THE MACHINE AND SEE WHAT HAPPENS, GOOD LUCK BROTHER SR TECH
Nov 06, 2008 | Brother MFC 7300C InkJet Printer
Machine errror 41 of brother mfc 3100c
Error 41 is common problem for all Brothet MFC printers.
To fix it, you have to change the Print heads of your printer.If your printer is still under warranty, call Brother 1-800-276-7746(Voice) 1-949-859-2272 (Fax)
and get yourself a new Printhead "free of cost".
Feb 11, 2008 | Brother MFC 3100C All-In-One InkJet...
Scanning with the brother mfc 7300c
FIRST OF ALL YOU WILL NEED TO INSTALL THE BROTHER MFC SUITES CD THAT CAME WITH YOUR MACHINE, WHEN YOU HAVE DONE THE INSTALLATION, BRING UO THE PROGRAM PAPER PORT OF YOUR MONITOR, PUT THE COPY THAT YOU WANT SCAN ON THE FLAT BED, IN THE UPPER LEFT HAND YOU WILL SEE PHOTO OR TEXT CLICK WHICH EVER YOU ARE SCANNING, NOW CLICK SCAN ANOTHER SCREE WILL COME UP AND ASK YOU IF YOU ARE USING THE FKAT BED( THE GLASS OR THE DOCUMENT FEEDER. CLICK THAT, NEXT TELL IT AGAIN PHOTO OR TEXT OR WHAT EVER THEN CLICK SCAN, ON THE SCREEN YOU WILL SEE THE SCANNING TAKING PLACE, THEN YOU WILL SEE THE SCANNED ITEM  EITHER IN MY DOCUMENTS OR MY PICTYRES DEPENDING WHERE YOU TOLD YOUR COMPUTER TO PUT THEM HOPE THIS HELPS, GOOD LUCK BROTHER SR TECH
Nov 13, 2007 | Brother MFC 7300C InkJet Printer
Printing Problem
SOUNDS LIKE YOU ARE REFILLING YOUR OWN CART. THEY DO NOT WORK WITH BROTHER MACHINE, THE BROTHER MACGHINES ARE SET TO WORK WITH OEM PRODUCTS, CHANGE YOUR INK GOOD LUCK BROTHER TECH
Jan 24, 2007 | Brother MFC 7300C InkJet Printer
Printhead
TRUST ME , IF YOU HAVE NEVER PUT A PRINT HEAD IN YOU ARE IN DEEP S--T. MAYBE THE SERVICE CENTER OR WHO EVER SOLD THE PRINT HEAD TO YOU WILL DOWN LOAD THE INSTRUCTION SHEET. MAYBEEEEEEEEEEEEEEEEEEEEEEE THEY WILL DO IT I DO NOT KNOW AS THIS PRIORITY INFO, GOOD LUCK BROTHER SR TECH
Aug 29, 2006 | Brother MFC 7300C InkJet Printer
Brother MFC 7300C InkJet Printer Logo
123 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
