Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton kerosene heater 3E219B will not turn on
I plugged in the heater and it ran without igniting for about 10 seconds then shut off. I dried the excess kerosene off and the heater still will not do anything when plugged in. Reset button does nothing.
  • scaamano80 Feb 10, 2009
    thanks for the info. problem was a stuck reset switch, fixed it thanks
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Posted on Dec 05, 2009
  • 232 Answers
  1. Determine if there is spark at the plug
  2. no spark? check the transformer. Is 110v going in but spark not coming out? check for ground. If grounded, replace the transformer with the modern replacement 102482-01 .
  3. No 110v going into the transformer? check the reset. If defective, replace with the modern replacement HA3003
  4. If 110v coming in and out of the reset, replace the photocell HA3019
Posted on Feb 06, 2009
I just turned on my dyna-glo kerosene topedo type heater and it run for about 10 seconds without igniting and then shuts off with a red flashing indicator light on!
the photo electric cell is not working
it is doesn't see fire , it shuts off the fuel so that excess fuel is not going to the chamber that can cause an explosion or fire if it ignites
new items , take it back for a warranty check or refund
for older units tale it to a service agent for repairs
Dec 08, 2016 | Dyna-Glo Heating & Cooling
I have reddy pro 170 i plug it in , the fan & igniter comes on for 10 to 15 seconds then shuts off ,blew through fuel line and nozzle still same result, i do see fuel mist coming out nozzle ,i dont k
You must make sure the mist is not to close to the igniter . If it is it wont be misty enough to ignite. And make sure its in the path of the mist. If its new return it to the store.
Feb 07, 2015 | Reddy Heater Pro-Tough Kerosene/Diesel...
My heater runs for 10 seconds,then shuts off.It runs on kerosine but has to be plugged in at all times.Why then, do we need kerosine?
Being lugged in allows the blower to work (if you have one) and also is part of the ignition system. Without kerosene there would be no flame/heat.
Feb 02, 2011 | Heating & Cooling
When i plug in my unit it turns on for about 5 seconds and shuts off. doesnt ignite
Check the fuel and tank. If it has been a while since fuel has been refilled, or it has sat without, you may have water in the tank.
Feb 21, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Will not fire
this unit operates with a small air compressor at rear of motor. Remove the solid 1/8 inch plastic plug. install a low pressure gage. you should read around 5 psi
Feb 28, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Heater will not turn on
First you need to get the power problem solved. pull the cover by the reset switch off and check the fuse. Once you have power again and it does the same thing it's most likely the ignitor thats bad. With the top cover off turn it on and watch the spark plug to see if you have spark. If you have good spark then it's the high heat sensor.
Jan 31, 2009 | Dayton E52 Utility Heater
150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
check for proper pump pressure. Restricted fuel flow. Proper venting of fuel cap.
Feb 19, 2008 | Dayton E52 Utility Heater
Heater wont work
Dayton heaters. com?
14 years old? dayton still exist?
Stop trying to blow self up--go buy new one
Jan 21, 2008 | Dayton (3E379) Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
964 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
