Question about Dell Inspiron 1300 Notebook
Ok Im not getting anywhere....
Each time I get a response I read it and have to make it more clear. Ok here goes. I have a TS-632D ver.3 dvdrw drive but the only problem is that its not on my device manager, and my computer. It turns on when I boot up and I have tried to search for free software for it from the company. It is nowhere located on the laptop system. So I have a drive that works(powers up) but doesnt do a thing. Doesnt read or write dvds. When I click on the icon it says insert cd. And now I am wondering should I buy a new drive or is this a plug in play drive that I have? So once again...its not registrying on device manager and isnt anywhere in the system. I can get firmware but I need the software for it if it comes with software. This is so complicated.....wow!
    President:
  • 2,692 Answers
Here is your product support webpage .
Click on the CD/DVD firmware,download and install.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON1300/B130&os=WW1&osl=en&catid=&impid=
PS You are correct,As long as a player/burner has power attached to it it wil light up and run but this had nothng to do iwith it communicating with the computer. This only had to do with the mechanics of the device.
Posted on Feb 01, 2009
  • Thomas F. Schneider Feb 01, 2009
    Withthe low rating I an guessing you still are not able to make it clear.
    Rots of Ruck
Device not reading nothing
When was the last time you cleaned the lens?
Jan 14, 2014 | Samsung TS-L633A DVDRW R DL drive - Serial...
The speedometer works part of the time to read right speed and then it goes crazyreading what ever it wants either high or too low some times it gets stuck on 15 mph in park or reads 10 to 15 when driving...
If the car is otherwise working OK, it's probably your instrument cluster (IPC). There is an electronic sensor on your transmission that sends a signal to your engine computer (ECM) and the IPC. Your transmission changes gears in response to this sensor, so if it's shifting properly, and the other gauges are ok, the ECM should be OK
Jul 17, 2017 | 2004 Chevrolet Monte Carlo
TS-L633A firmware update
Follow these steps to resolve your cd dvd issue. It's mostly caused by an error in the registry.
Before you proceed, create a backup of your registry.
Manual steps to back up the registry in Windows XP
1. Click Start, click Run, type %SystemRoot%\system32\restore\rstrui.exe, and then click OK.
2. On the Welcome to System Restore page, click Create a restore point, and then click Next.
3. On the Create a Restore Point page, type a name for the restore point and then click Create
4. After the restore point has been created, click Close.
Note If System Restore is turned off, you receive a message that asks whether you want to turn on System Restore now. Click Yes. Then, in the System Properties dialog box, click to clear the Turn off System Restore check box, click OK, and then repeat this step.
The next step is as follows:
First and foremost, go to My Computer; right click on properties, hardware, and then Device Manager.
Right click on the CD DVD drive and uninstall it, then click OK, then close.
Next Step:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot
your computer
Jun 28, 2012 | Samsung TS-L633A DVDRW R DL drive - Serial...
Dell gx 260 there is no disc in the drive.
OK, first of all you said you put a blank DvD in the drive. Make sure your dell has a DvD writer. Look on the drawer of the drive and see does it say DvDrw or DvDROM. It has to say Rw for rewritable and not ROM for Read Only Media. Maybe you have a Combo Drive that is DvDrom and CDrw which means it will read both DvD's and Cd's but in can only Write CD's.
If in fact you do have a DvD writer make sure you're not trying to put a Blue Ray disc in the drive.
Lastly, remove the DvD from the drive. Click Start/My Computer. Notice what it brings up as to your DvD Drive. Does it Say DvDrw or just plain ole DvD. DvD means it will only read a DvD.
Mar 20, 2012 | Dell OPTIPLEX GX260/SMT P4 2GHz 512MB...
I own a DVD Writer Model TS-T632A CD drive in my HP and it recently stopped working. it will not read CD's. Anyone have a solution on how to fix it or what the problem may be?
Alot of time cd drives the eye will go bad or get alot of dirt/dust on them. They are really cheap to replace that would be the best option.
Mar 07, 2011 | Toshiba Samsung TST632 8x DVDRW DL...
Maytag neptune MDE9700AYW ts t5 error
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Hope this helps
Jul 25, 2009 | Maytag Dryers
Inspirion B130 DVDRW drive
On the bottom of the notebook under the DVD drive push the latch to eject the DVD module. Once the module is ejected gently re-insert the module using both thumbs until you hear a click. Your DVD should now be recognized by the computer.
Feb 01, 2009 | Dell Inspiron 1300 Notebook
Ok my inspiron 1300 dvdrw drive isnt....
hah. last time i had this happen it was hardware failure on the cd/dvd drive... i hope this isnt the case!
these drives always have satisfactory drivers in windows itself. in your device manager, (control panel--> system-- hardware tab--device manager), does it show your drive in the right place? or is it below in the yellow question mark category indicating that there's a problem?
from your descrition, it sound a bit like you have a bad disk in there not a bad drive, but that's just a guess at this point.
in the device manager, if you "uninstall" your drive, on reboot, the drivers will be installed again ( I assume you have windows xp?). this may help refresh your drivers...
I remember in an older laptop, I upgraded to windows xp service pack 3, and it was that service pack that made my drive at weird, so i went back to sp2
Jan 31, 2009 | Dell Inspiron 1300 Notebook
Dell Inspiron 1300 Notebook Logo
Alun Cox
